586,693 active members*
3,065 visitors online*
IndustryArena Forum > MetalWorking Machines > Drilling- and Milling Machines > TREE 840 VMC - NEED HELP GETTING HER GOING!!! (pic inside)
Results 1 to 1 of 1
    Mar 2015
    9
    Hello all,
    I own a Tree 840 VMC that I have yet to see running!
    See attached pic for the faults I am seeing.
    On the rear of the machine on their are two cabinets. Facing the rear, the cabinet on the right houses what appears to be a power supply and driver boards. The cabinet on the left has a power supply and fan at the base but I realized this weekend that it's not hooked up.
    I'm not sure if this is an auxiliary power supply or what it is - any ideas?
    I'm also reaching out to zps to see if they will help.
    Thanks in advance for any help you may provide.
    Shawn
