586,106 active members*
3,104 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Help with adding a spindle and vfd to controller
Results 1 to 10 of 10
    Picked up a velox cnc machine that pretty much new, its a few years old and running a parallel box.
    Id like to move from a slow dc motor to a spindle but my controller doesn't support it, I am fairly green on messing with the electronic end of these, any help?
    Sent from my SM-G955U using Tapatalk
    Dec 2017
    82
    Re: Help with adding a spindle and vfd to controller
    If you can not connect the vfd to your
    Controller it is not a big deal.
    just buy a vfd and spindle then you can turn it on manually by a switch and potentiometer for adjusting the rotary speed
    then you can run the gcodes
    After job is done then turn off the vfd from the switch.
    I knew i couldn't, but wondered if there was a simpler breakout board i could use to do so.
    I think i can control speeds from vfd by changing frequencies, i think
    Quote Originally Posted by mattcnc123 View Post
    15362
    Quote Originally Posted by purplepeopleeater View Post
    What control software are you using, and yes a simple Breakout Board that has PWM 0-10v output can do what you want depending on your control you are using
    Mactec54
    What control software are you using, and yes a simple Breakout Board can do what you want depending on your control you are using
    Mach3, its a velox parallel controll box too
    15362
    Check your Breakout Board outputs you may already have a 0-10V PWM output and a spare relay for turning the VFD On/Off
    Mactec54
    No spare relays inside unfortunately
    Dec 2017
    82
    Where are you located ?
    if you want I can upgrade your velox cnc to new electronics
    then you can control the vfd from the software.
    email me your contacts.
    Im pretty sure my BB just needs relay and control wire posts yes?
    Im in Washington state, whats your email... sent one to the one listed in profile
  1. How would I no if controller will accept 4th axis? Adding rotary head
    By jeeperjp in forum Stepper Motors / Drives
    Last Post: 12-13-2015, 10:55 PM
  2. Replies: 0
    Last Post: 08-23-2015, 07:14 PM
  3. Adding a 4030 Driver to the 3-Axis Controller
    By Sbthomas13 in forum Automation Technology Products
    Last Post: 10-31-2009, 05:48 PM
  4. adding cnc controller to solidcam
    By synv in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-13-2008, 10:37 AM
  5. Help Needed Adding a Third Axis to Techno Inc Controller
    By jlettman in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-13-2008, 08:16 PM
