586,114 active members*
3,381 visitors online*
Page 18 of 18 8161718
Results 341 to 350 of 350
  1. #341
    Apr 2016
    841
    Re: New 2x4 Saturn build
    Quote Originally Posted by Ntl View Post
    The material is just under 24"x36" Vcarve estimated time was 3 hrs, but Centroid is always faster than the estimated times I've noticed.
    Good evening Dan,
    The discrepancy isn't attributable to Centroid. The same thing happens with Mach3 and Mach4.
    Take another look at the VCarve time estimate screen. If it's like Aspire (what I use), it says, "Time estimates based on" "Rapid Rate" and "Scale Factor." Assuming you have your rapids set correctly, you need to play with the scale factor until you get an estimate that reflects the actual time. Hopefully, that will get you close the next time. For me, I don't care much about cutting taking less than the estimated time. Underestimating is another matter. If cutting was running long, I'd start adjusting the scale factor.
    As I understand it, the scale factor is not linear, e.g., assuming the estimate was twice the actual cut time, cutting the scale factor in half won't necessarily get you there. Apparently, there are a number of things scale factor takes into consideration, like feed rate, so a simple algebraic equation doesn't work. At least that's what I've read. Fortunately, trial and error isn't that big a deal in this case. Just change the factor and rerun the estimate until you're happy with it.
    Gary
  2. #342
    Aug 2018
    621
    Quote Originally Posted by OlfCNC View Post
    Then Vcarve calculating the time incorrecly or the Centroid doing the feedrate incorrectly.
    What the UCCNC laser plugin calculates for this kind of laser engraving jobs is always correct however it is the same software who makes and executes the code, no need for Vcarve.
    It's not laser engraving it's done with a v bit and vcarve has some settings you enter to get the desired look you want. I'll take a close up photo so you can see that there is depth to the image. Thanks for the info
  3. #343
    Aug 2018
    621
    Quote Originally Posted by GME View Post
    Good evening Dan,
    Gary
    I'll play around with the settings, maybe I don't have the rapids set right in vcarve. How do you like the parts I posted? Wasn't really asking for any help with Vcarve but thanks for the info regardless.
  4. #344
    Apr 2016
    841
    The pieces are very nicely done.
  5. #345
    Aug 2018
    621
  6. #346
    Aug 2018
    621
    Here's another one I just did, they are getting better I think. There's also a close up so you can see there's some depth to the machining.
  7. #347
    Sep 2005
    1740
    Very nicely done. Getting ready for winter here in Iowa.
  8. #348
    Apr 2016
    841
    Quote Originally Posted by wmgeorge View Post
    I thought you were headed south. Given up on moving to Florida?
  9. #349
    Aug 2018
    621
    Oh man I bet it gets chilly in Iowa we complain when it's in the 50's. But I'm sure you guys would say the same when it's 115 out here in the summer.
  10. #350
    Jan 2007
    251
    Holy crap NTL. Those look amazing. You have come a long way from that first knotty 2x4 you milled.
    Jack
  1. Saturn 2 4x4 Build/Assembly
    By bubba58 in forum FineLine Automation
    Last Post: 05-02-2018, 02:24 PM
  2. New Saturn 2 4 x 4 CNCRP Nema 34 build
    By micknm in forum FineLine Automation
    Last Post: 12-19-2017, 10:25 PM
  3. 2nd Build (first) - Saturn CNC 2'x4'
    By difalkner in forum FineLine Automation
    Last Post: 11-11-2017, 12:56 AM
  4. Saturn 4 X 4 build
    By sybilsurf in forum FineLine Automation
    Last Post: 03-19-2017, 01:47 AM
  5. Build Thread Saturn 2x4
    By newcarver in forum FineLine Automation
    Last Post: 11-01-2016, 01:00 AM
