586,033 active members*
2,941 visitors online*
IndustryArena Forum > Manufacturing Processes > Milling > glass cutting by milling
Results 1 to 6 of 6
    Sep 2018
    hello!
    i am new here ans already lost a previous same post,
    i design a glass cutting milling machine with 2 axis control .(simple).
    i need help regarding the spindle torque over 25K rpm
    the milling/cutting tool is diamond coated 14 m"m bit to cut 8 mm simple glass.(it has internal water cooling channels).encl. photo of bit.
    anyone has experience or knowledge of which kind of minimum torque or maybe motor power or type
    to use to get it doing the task.
    its important not to use overkill power and quite process (since all is used inside a private home)
    thanks
    Attached Files Attached Files
    Sep 2018
    I think yow can cut glass with waterjet
    Nov 2018
    go big and use CNC machine
    Dec 2018
    9
    waterjet is ok, I think.
    Jan 2019
    waterjet,Have you tried it?
    Jan 2019
    waterjet is ok.
    geometry dash
