586,540 active members*
2,799 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Guilloche Pattern Generator (g-code, .dxf vectors and .bmp output)
    Aug 2011
    999
    This software does not fulfill any practical purpose...just for decorative patterns to be used with v-carving, engraving or diamond drag bits. It is like a very configurable spirograph with selectable number of loops, traces, orientation, trace width etc, that can generate circular, rectangular or linear guilloche patterns and output as g-code, .dxf vectors or bitmap image. The g-code can be specified for flat (x-y-z) or rotary machining (x-z-a or y-z-b). In case of rotary output, variable radius blanks can be used (e.g. cones, barrel shapes etc.).
    For more information, see HERE.
    Attachment 402642
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
    Apr 2007
    Re: Guilloche Pattern Generator (g-code, .dxf vectors and .bmp output)
    Jerry,
    Looking for find more information or the Guilloche and Maze software once offered.. Nothing left to download on Tailmaker.net website and states the site will cease in April 2020. I
    tried sending an email inside the website with the following message and was hoping for a reply to TodLJohnson at yahoo dot com
    Thanks...
    Hi Sir,
    I just tonight came across your website from a CNC blog about mostly Guilloche pattern generator but mazes as well.
    Sadly, noticed your message about software discontinuance and not link for downloading your software? I have an
    old guilloche addon for Corel Draw and saw your patterns were very interesting. Is there anyway to download and
    try or acquire a zip file or something? My primary reason would be to export DXF files to use in Corel Draw.
    Any chance I could try or procure your files. Photos appear to make all the parameters highly programmable.
    Thank youi so very much. This is a hobby of mine and I would be most grateful. Thank you and Happy New Decade.
    Nov 2014
    9
    Looks like it is available here! https://fabrikisto.com/tailmaker-software/
    Aug 2011
    999
    Quote Originally Posted by parentevan View Post
    Yes it is...
    I abandoned my old tailmaker.net site when I shut down the software business and since it seems to have been taken over by Internet demons. Not safe to go there anymore...
    But fortunately, Joe Federer at fabrikisto.com volunteered to host my software as a freeware . Please feel free to look around!
    JB
  1. Guilloche Generator Software
    By JerryBurks in forum Wooden Clocks
    Last Post: 09-14-2018, 02:21 AM
  2. HELP!!!!!Can I regenerate vectors from saved g-code
    By Jammie in forum Chinese Machines
    Last Post: 09-23-2017, 02:55 PM
  3. BEST g-code generator
    By cncspadeto in forum G-Code Programing
    Last Post: 08-22-2014, 12:16 PM
  4. drill pattern generator
    By robe_uk in forum Uncategorised CAM Discussion
    Last Post: 06-29-2013, 02:01 AM
