586,112 active members*
2,999 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Affordable Yaskawa service or change servo amp type? VM17 Cent VI
    Oct 2014
    We have Yaskawa SGDB-10ADG drives in our Partner VM17 mills.
    Is there an affordable & reputable repair service for these drive amps? I had one repaired by Yaskawa a few years ago, and I think it ran $1000-$1200, that was their flat fee at the time.
    One amp is flaking out, and we have a problem with something in the loop on another axis encoder/encoder cable issue or possibly amp. I can see there's an option in the system to use non-Yaskawa servos but I don't recall there's any info in the manual on how to switch. I'm curious if there's a viable switch to other system that's less onerous.
    15362
    Re: Affordable Yaskawa service or change servo amp type? VM17 Cent VI
    Quote Originally Posted by JDM5 View Post
    No you can't use a different servo motor, sometimes you can find these drives and motors on Ebay for good prices like this looks like a repair service and exchange so they may be able to help
    https://www.redrive.biz/SGDB-10ADG-Y...sgdb-10adg.htm
    https://www.ebay.com/itm/292372584253
    Mactec54
    Nov 2013
    128
    Stick a sigma 2 yaskawa drive and motor in it. At least then if the drive fails later you can do either a sigma 2 or 5 for a replacement. You can probably find the pair for under a G on eBay.
  1. VM17 Tool change height
    By Ozfab in forum Milltronics
    Last Post: 05-01-2018, 12:11 AM
  2. MR-J40A servo amplifyer - Need help to change Servo loop type
    By pheonc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-18-2013, 11:09 PM
  3. Change from yaskawa servo to delta servo
    By sachin.kumar in forum Servo Motors / Drives
    Last Post: 11-02-2012, 06:31 PM
  4. Sherline/Taig affordable tool change spindle
    By dwalsh62 in forum News Announcements
    Last Post: 07-10-2012, 03:12 AM
  5. How to change backlash in Partner 1/cent 5?
    By jswalwell in forum Milltronics
    Last Post: 04-14-2009, 07:01 PM
