586,082 active members*
3,837 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Is a 400w servo adequate for RF-45 Z-axis?
    Mar 2017
    98
    Hi pretty much as subject says, is a 400w servo adequate for RF-45 Z-axis? I am picking up some older DMM 400w servos (60EM-DHT-36) and I'm wondering if they'll move it up and down if I counter weight it.
    Feb 2012
    41
    Re: Is a 400w servo adequate for RF-45 Z-axis?
    If it is truly counter weighted it will move up and down with the touch of a finger. Meaning the counter weight is the same as the head . But if you just did the weight less than the head you still have head weight to help eliminate vibration and your motor will still lift it.
    Quote Originally Posted by j3dprints View Post
    Sent from my SM-G900R4 using Tapatalk
    15362
    They might work, the Z axes is always a challenge, on these machines a 5:1 gearing might be where you need to be even with it balanced with a counter weight, 3:1 may work would be a good starting point, they will work on the X and Y with 2:1 gearing
    Mactec54
    May 2008
    1185
    How much toque at 1000 RPM?
    youtube videos of the G0704 under the name arizonavideo99
  1. Replies: 6
    Last Post: 11-20-2015, 07:11 PM
  2. G0704 - Adequate Y-Z Gap is What ?
    By datac in forum Benchtop Machines
    Last Post: 05-29-2015, 10:46 PM
  3. DMM 400W SERVO WIRING DIAGRAM
    By wantacnc in forum Dmm Technology
    Last Post: 06-25-2013, 02:28 AM
  4. What free servo controller used for brush DC motor 400W ?
    By Qwerfk in forum Open Source Controller Boards
    Last Post: 01-10-2013, 05:18 PM
