586,070 active members*
3,502 visitors online*
Thread: clearpath F1
    May 2015
    6
    clearpath F1
    i bought one servo to try out on the x axis. more info to follow
    Attached Thumbnails Attached Thumbnails 20180924_141352.jpg   20180924_141305.jpg
    Nov 2005
    218
    Re: clearpath F1
    Quote Originally Posted by chris24g View Post
    Following
    May 2015
    6
    Re: clearpath F1
    setup of the servo itself is straightforward, but a new experience cnc wise. would definitely advise running and setting up the servo fully on the bench before installing. since this is not really a stepper, you can put it in modes where it runs away (you can't stop it). no major incidents but that was an eye opener. the next hurdle is to figure out how to install the pinion, as there is no set screw. solutions are:
    1) drill the shaft for a pin
    2) loctite the piinion
    3) source a new pinion with a set screw and grind a flat spot on the clearpath
    anyone know the pinion specs? looks to be 16 tooth
    Mar 2004
    1806
    Re: clearpath F1
    Chris24g
    When I got my first clearpath, reading the specs, the manufacturer recommends against setscrews and keyways on my NEMA 23 series servos. They advise a couple of different friction fit pulleys instead.
    Art
    AKA Country Bubba (Older Than Dirt)
  1. Question for Clearpath servo users...
    By bobmagnuson in forum Servo Motors / Drives
    Last Post: 03-22-2018, 05:28 AM
  2. Clearpath Servos for Tormach?
    By GLCarlson in forum Tormach Personal CNC Mill
    Last Post: 05-02-2017, 01:31 PM
  3. Clearpath disabling
    By dbt3000files in forum Servo Motors / Drives
    Last Post: 10-18-2016, 05:04 PM
  4. Some advice and opinion on Clearpath servos
    By KennyPowers in forum Servo Motors / Drives
    Last Post: 09-11-2016, 09:22 PM
