586,072 active members*
4,739 visitors online*
    Need help identifying pinout
    I'm working on ordering (or building, depending on my options) a male DB25 to female DB25 adapter for a client. I have ordered a new cable for a duplicate machine, however upon inspection, the pinout layout is significantly different than the one I'm currently using. The pinout pattern I need to replicate is attached. I'm hoping this part exists out there, but if I have to build it myself with a kit I will. Thanks for your help in advance.
    Dec 2013
    5717
    Re: Need help identifying pinout
    I'm sorry but I'm having a bit of trouble understanding you're diagrams, not sure what is what. But it looks like a standard 25 pin null modem connection. Google is your friend here.
    Jim Dawson
    Sandy, Oregon, USA
    Nov 2012
    1267
    Exactly, it is a null modem cable. Rx/Tx are swapped (pins 2 and 3), DTR loops back to DSR and CD (pins 20, 6 and 8), RTS loops back to CTS (pins 4 and 5).
    Nov 2007
    361
    Quote Originally Posted by caitlinkehoe View Post
    This looks alot like a fadal cnc rs232 connection . They used this pinout for their controllers before changing to fanuc
    If this is for a fadal machine..... since both ends are 25 pin the 7 pin goes straight thru if it was a 25 to 9 pin it would fo to the 5 pin check out rs232 pinout for fadal
  1. nsk em cn2 pinout
    By dim371 in forum Servo Motors / Drives
    Last Post: 03-05-2019, 12:28 AM
  2. LPT Pinout
    By Controller2 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 07-17-2013, 12:25 AM
  3. MV Jr Serial Pinout
    By andyhol in forum Uncategorised MetalWorking Machines
    Last Post: 10-30-2009, 11:11 PM
  4. Signalstecker pinout
    By Gerisz in forum Servo Motors / Drives
    Last Post: 11-12-2008, 09:41 AM
  5. DB9 pinout cabling
    By miguisu in forum DNC Problems and Solutions
    Last Post: 05-23-2007, 12:21 PM
