586,060 active members*
3,380 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > Wiring setup for sewing machine motor?
Results 1 to 7 of 7
    May 2006
    309
    Do I need to insert the foot pedal wire to the control box in order to get it to work or will it be possible to just short-circuit some of the contact points with a jumper?
    24221
    Re: Wiring setup for sewing machine motor?
    Depends on the type of motor, the older ones were simple Universal motors, now BLDC are usually used.
    Al.
    Albert E.
    May 2006
    309
    Al.
    I have the csm2000. I tried to get it to run, but it will only do a few rotation at a very low speed and then it stops up. I need to swich of and on the 0/1 button in order to have it to run again, but then the same thing happens.
    What may be wrong?
    Jun 2011
    68
    Have you replaced the foot-pedal with a potentiometer?
    How is it wired?
    The motor must have the pedal or pot in the off position to "ARM"...this is the safety interlock system....
    Then you can adjust the pedal/pot to desired speed..
    Stuart
    May 2006
    309
    Quote Originally Posted by sclelectronics View Post
    How is it wired?
    Stuart
    Here is a link to another thread where I got a solution.
    Sep 2019
    I think it depends on the type of motor the sewing machine has.
    Dec 2019
    8
    I agree that sewing machines with pedals are another era. The market has new sewing machines that are much better than old ones. Sewing machines also suffered big changes thus becoming easier in use, compact and affordable. I highly advise you to buy a new computerized machine. Read more here the reviews of top five best sewing machines reviewed already in 2020. These reviews are a great start to understand what market offers you and what to fit your preferences and requirements.
  1. G540 to Consew Type Servo Sewing Machine Motor
    By IdefixRC in forum Gecko Drives
    Last Post: 10-31-2019, 11:57 PM
  2. Which belt and pulley wheels for sewing machine motor?
    By jaru-eri in forum Taig Mills / Lathes
    Last Post: 09-09-2018, 07:32 AM
  3. In need of machine setup/wiring help
    By ryguy_nayr in forum Waterjet General Topics
    Last Post: 01-07-2012, 12:32 AM
  4. Sewing machine Servo?
    By Max Power in forum Servo Motors / Drives
    Last Post: 11-16-2006, 03:16 AM
