586,068 active members*
3,706 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Post processor Heidenhain 4 axes for camworks L X+0 Y+0 A+0 R0 FMAX
    Aug 2016
    4
    Question Post processor Heidenhain 4 axes for camworks L X+0 Y+0 A+0 R0 FMAX
    Hello,
    Would you have a post-processor 4 axes continuous heidenhain TNC 410 or other that generated codes of this type: L X+0 Y+0 A+0 R0 FMAX A = angle in degrees for the 4th axis divider A = 0 ° (it's very simple)
    Could you help me, I'm really blocked and desperate
    I am looking for a post processor heidenhain TNC 410 or 426 with divider 4 th axis.
    I found on this forum several post processor with 5-axis indication.
    I tested these post processor heidenhain 5 axis, it does not work.
    He takes out a code that does not exist on heidenhain.
    I put you the program solidworks with integrated camworks it is a cam machined in 4 continuous axes
    here is the code out by the post processor (my post processor and the 4 post processor 5 axis on this forum) identical code
    0 BEGIN PGM MSRC131 HEIDENHAIN TNC 530 5 AXIS MM
    1 BLK FORM 0.1 Z X + 0. Y + 0. Z + 0.
    2 BLK FORM 0.2 X + 0. Y + 0. Z + 0.
    3; -12 MM 3 Dts CARBIDE Ticn
    4 TOOL CALL 06 Z S4244 DR-6.
    5 * A + 0. R0 F MAX
    6 LM81
    7 FN20: WAIT FOR SYNC
    8 FN20: WAIT FOR I12 == 1
    9 LM80
    10 L Z + 214.988 R0 F MAX
    11 L X + 43.05 Y + 0 Z + 214.988 R0 F MAX
    12 L X + 43.05 Y + 0 R0 F MAX
    13 L Z + 214.988 F MAX
    14 L Z + 207. F MAX
    15 L Z + 195. F80
    16 * A + 0. R0 F MAX
    17 LM81
    18 FN20: WAIT FOR SYNC
    19 FN20: WAIT FOR I12 == 1
    20 LM80
    21 L Z + 214.988 R0 F MAX
    22 L X + 42.979 Y + 0 Z + 214.988 R0 F MAX
    23 CYCL DEF 247 INIT. PT REF. ~
    Q339 = + 0;
    25 * A + 0. R0 F MAX
    26 LM81
    27 FN20: WAIT FOR SYNC
    28 FN20: WAIT FOR I12 == 1
    29 LM80
    This code does not exist on all heidenhain models:
    5 * A + 0. R0 F MAX
    6 LM81
    9 LM80
    1) Result Error. The FN is given special system FN20 does not exist for a non-continuous divisor one uses M functions
    2) The program does not output angular values, so not even possibility to manually transform the program
    For a correct code on continuous 4axes it would be necessary to write:
    I put the cam file on solidworks / camworks.
    I put the post processor 4 post processor and mine gives the same result.
    I put you the code generated by the post processor
    I thank you in advance
    I am French, my English is not very good
    here is my website : accueil - Sarl Dassonville
    Attached Files Attached Files
    Aug 2016
    4
    Re: Post processor Heidenhain 4 axes for camworks L X+0 Y+0 A+0 R0 FMAX
    I've never seen camworks running in 5-axis, except on video on youtube.
    Have you ever seen this software really work in 4 or 5 axes?
    Is on which numerical control?
    I may be looking for something that does not exist.
  1. Heidenhain iTNC530 post for CAMWorks 2014
    By ghevari in forum CamWorks
    Last Post: 01-16-2015, 04:59 PM
  2. Replies: 3
    Last Post: 01-12-2014, 02:35 PM
  3. need post processor heidenhain 530 or 407 for camworks
    By suzoki in forum Post Processor Files
    Last Post: 01-09-2014, 12:35 AM
  4. Very simple question re. FMAX on HEIDENHAIN TNC 355
    By 88incher in forum Bridgeport / Hardinge Mills
    Last Post: 12-30-2013, 07:42 PM
