586,072 active members*
4,602 visitors online*
Results 1 to 6 of 6
    Mar 2011
    357
    are these drives and motors a good fit for each other
    I am considering buying 4 of these motors
    https://www.automationtechnologiesin...3h2100-50-4bm/
    and 4 of these drives
    https://www.automationtechnologiesin...tepper-driver/
    I am not great at all the electronic lingo. Very mechanical with some electronics knowledge. What I am looking for is your opinion on the compatibility
    of these motors and drives.
    I will be controlling them with GRBL on Arduino.
    Re: are these drives and motors a good fit for each other
    I'd get drives that can handle higher voltage.
    I run my 570oz motors at 60V.
    Mar 2011
    357
    Got a suggestion for that? Automation technology supplies that PS in a kit with these drives and motors. The PS is 48V 12.5A. What is more important the PS voltage or the amperage?
    What does the higher voltage do for you?
    Ya I know you are taking about the drives but I thought it best if I added the PS as well.
    Thanks I don't want to screw this up.
    The higher the voltage, the more torque you'll have at higher speeds, which will result in a higher top speed. The downside is that the motor will run hotter. But drives with idle current reduction can reduce some of that heat.
    The current rating should be the total of at least 2/3 of the rated torque of each motor. Three 6 amp motors would need a 12 amp supply. Having more amps doesn't make any difference.
    You'll need a drive like the KL-8060E or Leadshine DM860 or EM705.
    I'm using an Antek power supply.
    Mar 2011
    357
    which antek PS?
  1. motors-drives.....etc
    By grf in forum CNC Machine Related Electronics
    Last Post: 04-08-2012, 12:45 AM
  2. motors and drives what best for me
    By pr0bability in forum DIY CNC Router Table Machines
    Last Post: 02-03-2012, 07:57 PM
  3. Nanotec drives + steppers, any good?
    By gazmalman in forum Stepper Motors / Drives
    Last Post: 02-24-2011, 06:48 AM
  4. Replies: 2
    Last Post: 07-12-2009, 10:10 AM
  5. Has anyone had any good/bad experiences with RUTEX Drives?
    By Darc in forum Servo Motors / Drives
    Last Post: 12-18-2005, 02:36 PM
