586,060 active members*
4,514 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Group numbers of lathe G codes
    Aug 2011
    419
    hello pls, how to find group numbers of G codes for okuma lathes?
    "Imagination is more important than knowledge."
    Jun 2015
    4154
    Re: Group numbers of lathe G codes
    hello again kurmay, i searched a bit, and i could not find anything related to group numbers for G's, but only for mnemonic codes : pls check attached; i hope it helps ?!
    if i may, why do you need this ? is the 1st time when i hear about it / kindly
    Aug 2011
    419
    I just found them. I'm not sure if there is another.
    Jun 2015
    4154
    hi i looked a bit over it : maybe G138 goes at group 30, & G23 --> 38 ?
    what's the catch ? kindly
  1. Replies: 12
    Last Post: 04-09-2016, 01:33 PM
  2. Format 2, group 9 codes
    By trio in forum Fadal
    Last Post: 04-06-2016, 05:31 AM
  3. Lathe Post giving crazy numbers
    By lynn mynatt in forum BobCad-Cam
    Last Post: 05-29-2009, 01:32 PM
  4. belt numbers for 6" Craftsman Lathe?
    By shootingarts in forum Uncategorised MetalWorking Machines
    Last Post: 02-09-2006, 03:29 AM
  5. Programming lathe with radius numbers
    By mudwhump in forum BobCad-Cam
    Last Post: 06-07-2004, 01:14 PM
