586,419 active members*
3,200 visitors online*
Results 1 to 3 of 3
    Haas DS30SSY x axis lost
    Hi all,
    Our operator forgot to clamp the main chuck and had a minor crash. I replaced the tool and used the ATP to redo the tool offsets, now when the programmed x dimension is at 1.2000, the tool tip is actually at 1.0000. Any suggestions on what the issue is? Thanks.
    Dec 2013
    15
    Quote Originally Posted by Rippinhard View Post
    Hi all,
    It was probably not a minor crash
    Check the alignment of the Turret
    Mar 2017
    314
    Re: Haas DS30SSY x axis lost
    On the bright side, having Y axis makes it easier. If bmt Indicate turret bmt surf in Y for your curvic clocking.
    Indicate same in Z for turret skew. I like to then go the next step abd indicate the main spindle
    perpendicularity to X. If that is good I stop. If its outthen fix that and check concentricity of main to sub.
  1. Haas DS30SSY question
    By SanJus29 in forum USA Club House
    Last Post: 04-14-2016, 12:53 PM
  2. JOB OPENING! HAAS DS30SSY
    By taylors in forum Employment Opportunity
    Last Post: 04-30-2014, 03:06 PM
  3. Alignment of live tooling in a DS30ssy haas lathe
    By carguy001 in forum Haas Lathes
    Last Post: 07-25-2013, 04:29 PM
  4. Programming right spindle on DS30ssy
    By JBeeker841 in forum Haas Lathes
    Last Post: 04-16-2013, 05:10 AM
