586,070 active members*
3,543 visitors online*
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Aug 2015
    17
    Re: Spindle adjustment
    Quote Originally Posted by MichaelHenry View Post
    I removed the six SHCS from the rear (turret side) spindle cap and the cap rotates just fine about the spindle axis but is resisting my efforts to slide it. Is there a trick to getting this cap off the spindle housing? I'm assuming that trying to force it off with a small pry and any more than moderate force would be a bad idea.
    Michael, the spindle cap on the nose of the lathe only comes off if you take out the spindle. I have attached an image of the spindle removed from the lathe. Don't try and pry off the cap.
  2. #22
    Jun 2006
    3063
    Quote Originally Posted by Renovo View Post
    Thanks for saving me some grief - I apparently mixed up the meaning of front and rear.
  3. #23
    Feb 2007
    1538
    Hey Guys. Running my SP today and noticed something. It had started making a ticking and squawking sound - a bit like bearings dying.
    So I pull off the end cover and kept running parts - and tried different things - put a trace of silicone grease on the edge of the timimg belt - it looked like it was rubbing on the encoder pulley flange.
    That fixed it - it is quiet again now. If you try this dont use more than a trace - you dont want it getting on the main drive belt.
    Cliff
  4. #24
    Jun 2006
    3063
    Interesting - I'll check for that tomorrow.
  5. #25
    Michael, did you ever figure this out?
    Hate to bring back a year old thread, but knowing if you were able to get any help from Tormach might help with others deciding if they will purchase from them.
Page 2 of 2 12
  1. Spindle Orientation Adjustment
    By Aircraftman in forum Mitsubishi controls
    Last Post: 08-20-2021, 01:37 PM
  2. 8055M spindle adjustment
    By Beaker in forum Fagor Automation
    Last Post: 09-07-2015, 01:01 AM
  3. spindle control adjustment?
    By landslide1 in forum Fanuc
    Last Post: 12-20-2013, 01:51 PM
  4. SX3 Spindle Adjustment
    By mikemill in forum Syil Products
    Last Post: 05-21-2011, 03:57 PM
  5. spindle bearings adjustment...
    By javierr in forum Mechanical Calculations/Engineering Design
    Last Post: 01-06-2008, 07:21 PM
