586,110 active members*
3,162 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > G code limitations on tool radius compensatrion - any solutions?
    Aug 2006
    25
    I'm faced limitation of Kmotion Gcode interpreter which is inherited from NIST RS274NGC when using toll radius compensation - it does not allow conacave corners.
    Is there any solution how to force it round this corner what ever the tool radius is istead of just fail and abort gcode?
    Otherwise - any ideas how and where is best to implement it?
    Attachment 403196
    May 2006
    4045
    Re: G code limitations on tool radius compensatrion - any solutions?
    Hi funding33,
    KMotionCNC doesn't allow impossible paths.
    Rounding the corner properly would require looking ahead one or possibly many segments and in some cases becomes ambiguous.
    The code is located in rs274ngc.cpp. Search for:
    NCE_CONCAVE_CORNER_WITH_CUTTER_RADIUS_COMP
    Regards
    TK
    http://dynomotion.com
  1. New Tooling Plate Solutions From Tosa Tool
    By tosatool1 in forum HURCO
    Last Post: 11-25-2015, 09:18 PM
  2. New Tooling Plate Solutions From Tosa Tool
    By tosatool1 in forum Haas Mills
    Last Post: 11-25-2015, 09:05 PM
  3. Replies: 2
    Last Post: 02-11-2014, 01:17 PM
  4. Replies: 1
    Last Post: 05-15-2013, 08:52 AM
  5. EMC2 G-Code Rotary Radius Offset
    By metaprax in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-17-2009, 10:27 PM
