586,042 active members*
3,753 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Yaskawa Varispeed 626VM3 Fault A00
Results 1 to 6 of 6
    Jul 2007
    5
    I'm receiving a spindle alarm on my Hurco Mill that has a Yaskawa 626VM3 servo drive.
    The machine was turned off over the weekend. When I boot up the control The display on the drive has F-A00.
    Please let me know what this alarm is and what can be done to correct it.
    15362
    Re: Yaskawa Varispeed 626VM3 Fault A00
    Quote Originally Posted by darrelt View Post
    How are you powering your machine this is what a F-A00 fault is
    Mactec54
    Jul 2007
    5
    When the main power switch on the electrical panel is turned on the control boots up.
    Then there's a green power on PB in the center of the pendant I push then the cycle start PB.
    Then the machine would be fully powered up and ready to reference.
    5 seconds after the power on and cycle start PBs are push is when the spindle alarm occurs.
    15362
    What are you using to power your machine Electrical Power supply
    Mactec54
    Sep 2015
    25
    Did you resolve this issue
    Sent from my Moto G (5) Plus using Tapatalk
    Dec 2020
    I have the same issue, so how did you fix the problem
  1. Yaskawa Varispeed 626VM3 Help
    By Derwood1723 in forum Servo Motors / Drives
    Last Post: 05-13-2023, 08:35 PM
  2. Yaskawa 626VM3 Repair?
    By giz in forum Spindles / VFD
    Last Post: 04-08-2020, 10:28 AM
  3. yaskawa varispeed 626vm3.
    By wilko1 in forum Servo Motors / Drives
    Last Post: 10-23-2019, 01:42 AM
  4. matsuura cnc with Yansac varispeed 626vm3 strange problem
    By ivision in forum Servo Motors / Drives
    Last Post: 03-30-2014, 07:56 PM
  5. Trouble Varispeed 626vm3
    By Fyp Engineering in forum Servo Motors / Drives
    Last Post: 06-17-2013, 11:49 PM
