586,051 active members*
3,772 visitors online*
Results 1 to 6 of 6
    Mar 2012
    150
    Mach3 settings for UC400ETH
    How do I get Mach3 to get UC400ETH + HDBB2 to jog a motor?
    I have just connected 1 motor on the Zaxis.
    Then in the ports and pins I have enabled Z axis and set the Step as pin 6 and Dir as Pin 7.
    I have TB6600 as stepper drivers.
    Strangely, When I connect the enable to the driver (EN + and EN-) the motor shaft can be turned by hand but when I remove the enable to the driver the motor shaft cannot be turned by hand it is locked.
    Re: Mach3 settings for UC400ETH
    When the motor is locked, the drive is enabled. Most drivers are enabled by default.
    Mar 2012
    150
    Its good to hear that the drive is enabled. Any idea what I could look into to get the motor to jog. is the Pin setup 6 and 7 correct for Z axis on Mach3 for the UC400ETH. I can't find any info regarding Mach3 setup on the UC400ETH docs?
    Mar 2012
    150
    Ok, so I got it to work,
    I had to load the Mill profile, and then the motor started jogging. So far I was using the Lathe profile. The mill profile already had the pins and ports all setup. So didn't need to do any settings as such.
    However now when I jog X + or X - the motor only rotates in the clockwise direction. Any idea with the motor is not reversing? Is this an extra config in Mach3?
    Jun 2015
    943
    Quote Originally Posted by ZeroBacklash View Post
    The drive is not receiving the direction signal, only the step.
    Mar 2012
    150
    Quote Originally Posted by OlfCNC View Post
    Yes, got it, there was a mistake in the Pin assignments. DIR was wrongly assigned to 6 instead of 3.
  1. Mach3 with UC400ETH
    By MMC336 in forum Questions or Problems
    Last Post: 08-08-2018, 01:49 AM
  2. install Mach3 help, issue with UC400eth? Please Help
    By originalsigns in forum Mach Mill
    Last Post: 07-20-2017, 01:19 PM
  3. Mach3 UC400eth and joypad
    By silverdog in forum UCCNC Control Software
    Last Post: 04-21-2016, 09:14 AM
  4. UC400ETH and Mach3
    By vmax549 in forum UCCNC Control Software
    Last Post: 04-08-2016, 05:24 AM
  5. Mach3 CV settings vs. G-100 Plugin CV settings
    By Bfarn in forum Machines running Mach Software
    Last Post: 12-17-2008, 05:45 PM
