586,104 active members*
3,431 visitors online*
IndustryArena Forum > CAM Software > Vectric > going from 1/4 inch to 1/16 inch bit, do I go slower or faster?
Results 1 to 2 of 2
    Mar 2018
    I'm going to rout clock movement hands out of 1/16 plastic or aluminum, using a 1/16 inch router bit.
    I have only used 1/4 inch bits and 18000 to 20000 speed and 30 to 35 IPM on wood, with a shallow depth (0.08).
    My CNC router is small Shark 13x24 with a Bosch Colt router.
    Do I go faster or slower with 1/16 inch bit?
    35538
    Re: going from 1/4 inch to 1/16 inch bit, do I go slower or faster?
    About the same as you are using now with the 1/4" bit.
    But when you use a 1/4" bit, you should be cutting 5-10x faster at those rpm's
  1. Replies: 0
    Last Post: 08-10-2017, 07:57 PM
  2. Replies: 0
    Last Post: 01-19-2015, 11:44 PM
  3. Replies: 4
    Last Post: 09-11-2012, 10:30 PM
  4. Best way to mount 1/16 inch ball mill with 3/16 inch shank in router.
    By cjjonesarmory in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 07-02-2009, 11:38 AM
