586,103 active members*
3,277 visitors online*
    Mar 2018
    68
    add grounding
    I bought this spindle from solar.jean on ebay and was wondering how I should try to add grounding to this? The top cap and fan top are both plastic. The screw nearest the spindle mounting plate was stripped out and I was thinking I may be able to use that to get a ground connected.
    Jan 2007
    626
    Re: add grounding
    I can't tell where the stripped screw is.
    Any screw in the inside of the outer housing of the spindle and wired to the fourth empty pin on the spindle connector,should be fine.
    I assume its an air cooled spindle?
    A hint when posting pics. ( it took me ages to work this out...lol) crop the pic so its wider than it is tall and it should display correctly.
    Attachment 403376
    Mar 2018
    68
    Re: add grounding
    If I have continuity on earth to the spindle housing grbl throws a "hard limit" error every time I start the spindle. My limit switches have filters and I'm perplexed as to how to fix the noise issue.
    Jan 2007
    626
    Re: add grounding
    Sorry.....no experience with grbl
    Sent from my SM-G920I using Tapatalk
    ericks Guest
    Quote Originally Posted by jschoch View Post
    Noise usually goes back from the drive into the supply...so a filter just before the drive should help block that noise going into psu's etc. Also noise from the cabling can affect low voltage devices
  1. Grounding or?
    By warrenb in forum Maintenance DIY Discussion
    Last Post: 02-28-2014, 03:39 PM
  2. Grounding CNC Plasma
    By z28 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 04-03-2013, 03:36 PM
  3. Grounding the DC-K40
    By neptr in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-28-2012, 06:00 AM
  4. Grounding for DC-KIII?
    By B3nzilla in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-12-2012, 08:05 AM
  5. grounding Q's
    By anthony in forum CNC Machine Related Electronics
    Last Post: 05-14-2005, 11:24 PM
