586,033 active members*
3,079 visitors online*
    Mar 2018
    22
    Mach3 plasma issue
    I have a cnc machine we built, the issue I am having is that when I cat something on the machine and the torch is in direct contact with the steel it makes a small spark and then mach3 says there is a watchdog error,
    It also then throws out all USB ports like keyboard and mouse. I then have to unplug then and re-plug them to work.
    I use a mach 3 usb controller without a THC
    Apr 2014
    215
    Usb is very sensitive to electrical noise.
    There are many things that can propose the problem.
    As you know it is your plasma torch, what type of plasma cutter do you have (is it blowback start, high frequency start, scratch start)
    In the short term you can try to use ferrite cores to surprises some of the noise (they may not work with your plasma noise )
    There is also the possibility you need an isolated USB interface
    Normally with plasma ethernet is recommended.... However you may have other problems too (incorrect grounding and isolation)
    Good luck
  1. Mach3 plasma issue
    By japes in forum Controller & Computer Solutions
    Last Post: 07-03-2018, 04:22 PM
  2. Issue with Mach3 and USS
    By kgresiak in forum Mach Software (ArtSoft software)
    Last Post: 07-03-2018, 12:08 AM
  3. More of a Mach3 issue...
    By CROSSHATCH in forum Novakon
    Last Post: 06-18-2016, 01:28 AM
  4. Mach3 issue
    By Andrew2111111 in forum Machines running Mach Software
    Last Post: 02-10-2016, 10:41 AM
  5. Differences Between Mach3 Mill and Mach3 Plasma?
    By cjjonesarmory in forum Mach Plasma / Laser
    Last Post: 11-18-2010, 04:12 PM
