586,576 active members*
3,363 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Using CNC USB with fusion 360 on 3040 (what g-code?)
Results 1 to 2 of 2
    Apr 2019
    32
    I'm having great trouble finding a working code using fusion 360. I'm running cnc usb, the only codes I get to work in it are the ones generated through the online Easel program for cutting 2D shapes and paying outsourced 3D shapes through someone on fiverr.
    I've tried selecting many different machines on Fusion 360 but none work, some don't open at all, some open and seem to be working in the program but nothing happens at the router.
    Has anyone created working g-code in Fusion 360?
    Apr 2019
    32
    Re: Using CNC USB with fusion 360 on 3040 (what g-code?)
    Here's examples of code that works
    G21
    M3 S14000
    G90
    G1 Z3.810 F228.6
    G0 X7.707 Y54.103
    G1 Z-0.700 F228.6
    G1 X7.707 Y57.503 F762.0
    G1 X28.108 Y57.503 F762.0
    G1 X28.108 Y54.103 F762.0
    G1 X7.707 Y54.103 F762.0
    G1 Z-1.400 F228.6
    G1 Z-2.100 F228.6
    T1M6
    G0Z5.000
    G0X0.000Y0.000S40000M3
    G0X23.596Y105.792Z5.000
    G1Z-2.579F600.0
    G1X23.569Y112.398
    X23.569Y112.405
    X23.569Y112.412
    X23.582Y114.871
    X23.582Y114.901
    X23.583Y114.930
    X23.698Y117.638
    X23.701Y117.696
    X23.707Y117.754
    X23.896Y119.390
    X23.903Y119.440
  1. Replies: 3
    Last Post: 04-20-2019, 11:23 PM
  2. Mach3 reading fusion 360 g-code as error
    By mcdoggie in forum Machines running Mach Software
    Last Post: 08-10-2017, 05:49 AM
  3. G-code and fusion 360 engraving Programming needed
    By rokk in forum RFQ (Request for Quote)
    Last Post: 07-11-2017, 01:11 AM
  4. Autodesk Fusion G-Code EZPath II Post Processor
    By sabine in forum Bridgeport / Romi Lathes
    Last Post: 05-06-2017, 12:34 AM
  5. Replies: 0
    Last Post: 02-07-2017, 07:32 AM
