Hello
I have a blown Syil Xp5 spindel controller. I want now to replace the controller with a servo controller and a new motor with higher torque.
In order to have the same functionality (rpm, spindel start, stop, cc, cl) I have to interface the existing signal. I do not understand all of the function
of the syil board.
Conector on blown board: 15V | 5V | NC|NC|DIR|PWM|GND in some manual (www.hipoo.cn) on the net I found for some simlar
card: 15V|5V|TAP|S/P| F/R|PWM|GND
TAP: external electric low level, the tapping function is available. When motor runinng at 500rpm/m, high power or open, tapping function invalid.
I do not understand that!
S/P: Start/Stop in the shutdown state to a negative pulse start, turned down in a negative pulse stopped, a negative pulse every time a status change.
I don't understand. What happens?
F/R: is clear should be 0.6V or 0V.
PWM: Have to convert that to 0-10V (What's best?)
could anybody help?
