586,036 active members*
3,695 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > how to face-cut & zero-program ( basics reloaded : a bit faster, a bit optimized )
    Jun 2015
    4154
    hello sometimes i try to speed up things
    everybody knows how to face-cut and input program zero
    please check this :
    ... manual mode : put face-cut tool above the material
    ... automatic mode : program select + play
    ... open the door : if face is not clean, push cycle-start again
    program will read tool position, cut a face, reposition for a next cut at a predefined width, and declare Z origin / that's all-inclusive, 3-in-1
    - requires less keystrokes
    - faster than common-methods
    - noex + ctr + system variables + M02
    - it uses G97; if you wish for G96, consider also M61, etc
    - it reads&uses tool nose radius, but without compensation codes
    - i don't use the "wear" field; if you wish to use it, then VTWO* is needed
    - positioning is done in feed, not in rapid, so to avoid shocks caused by fast servos
    - works on random material diameter and face position, because it reads the tool position
    - to cover a wide range of diameters&materials, declare some generic values ( eq 750rpm 0.15mm/rot ) : even if specs are not high, it is still faster to run this "generic" program then operating in MDI; for fast adjustments, use the potentiometers
    - tested on osp300 / kindly
    Code:
        G50 S2000
        NOEX   V1 = 900000      ( n - rpm, o / min )
        NOEX   V2 = 0.789       ( f - feed, mm / o )
        NOEX   V3 = 0.50        ( z step      )
        NOEX LINK = 1           ( turret post )
        T + LINK * 101(01) ( M66 ) G97 S + V1 M42 M03 M08 G00 X + VSIOX - VTOFX [ LINK ] Z + VSIOZ - VTOFZ [ LINK ] M63
        G04 F0.345         ( be sure that there is coolant flow over the cutting edge, before feeding begins )
        NOEX V4 = VSIOX
        NOEX V5 = VNSRX [ LINK ]
        G01 X - 2   * V5   F + V2  G95
        G91 Z + 0.3
        G90 X + V4         F2500   G94 M05 M09 M63
        G91 Z - 0.3 - V3   F100
        NOEX VSZOZ = VSZOZ + VSIOZ + V3
    M02
    Jun 2015
    4154
    Re: how to face-cut & zero-program ( basics reloaded : a bit faster, a bit optimized
    hi nodochau, pls test this, it's pretty simple :
    ... download attached file and remove the *.txt extension
    ... replace "k" with "K" : 1st letter must be capitalized
    ... be sure that LINK variable = face tool turret post
    ... load it into osp300 lathe + program select
    ... clamp the material
    ... manual mode
    ... put face tool a bit above the material
    ... on Z, put it where you wish to take the 1st cut
    ... auto mode + cycle start
    tool will start moving down, towards X-, cut the face, then back up, and will put zero
    if face is not clean, push cycle start again / kindly
    May 2018
    74
    It is great and I will try it today.
    A question is why do we have this "X + VSIOX - VTOFX [ LINK ]" IF I just put X[VSIOX]? WHAY WE SUBTRACT VTOFX??
    Jun 2015
    4154
    well, try it as it is
    after that modify it how you like, and see what happens ... of course, use the feed potentiometer near 0%, thus to be sure that you know were the machine will go
    try to discover the answer by running trials yourself
    if you won't tell me why i put it there, i will tell you in a few days
    actually, that code is the key, this is why i opened this thread / kindly
    Jun 2015
    4154
    hello all, i have updated this code
    again, it is created for face cutting + auto Z0 declaration; there is nothing faster
    all you have to do, is clamp the bar inside the chuck, at random Z position, then manually bring the face tool above the material, and run the program
    parameters inside the program may be set only once, with generic values
    i added a parameter ( V4 ), so to choose if you wish to declare Z0 or not
    most of the math is buffered in a single-shot, by using noex+$, so to keep the calculations altogether & away from the executional blocks, so to target minimal downtime during program run
    kindly
    Code:
        G50 S2000
        NOEX V1 = 2000        ( n )
    $        V2 = 0.15        ( f )
    $        V3 = 0.50        ( z step      )
    $        V4 = 1           ( 1 : declare Z origin , 0 : don't )
    $      LINK = 01          ( turret post )
    $   LPX = VSIOX - VTOFX [ LINK ]
    $   LPZ = VSIOZ - VTOFZ [ LINK ]
        T + LINK * 101 G97 S + V1 M42 M03 M08 G00 X + LPX Z + LPZ M63
        G01 X - 2 * VNSRX [ LINK ] F + V2 G95
            Z + LPZ + 0.3
            X + LPX                F2500  G94 M05 M09 M63
            Z + LPZ - V3           F100
        IF [ V4 EQ 0 ] NJUMP
        NJUMP NOEX
    M02
  1. Replies: 6
    Last Post: 02-16-2019, 05:07 PM
  2. Replies: 1
    Last Post: 03-06-2017, 11:40 AM
  3. CAM program for face / body shapes
    By Malt in forum Uncategorised CAM Discussion
    Last Post: 01-12-2014, 06:58 PM
  4. Simple face program
    By KevinV_MEI in forum BobCad-Cam
    Last Post: 11-17-2012, 12:08 AM
  5. T-4 Parameters reloaded - now not working
    By serickson in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-11-2009, 04:02 PM
