586,075 active members*
3,646 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > Using printers parts to build foam cutter.
    Mar 2006
    14
    Hello,
    I have a couple of large multi-function (HP OfficeJet) mechanically working printers that I could break down for parts for a foam cutter.
    Has anyone done this, are there plans available.
    Thanks for any info,
    Tom
    Apr 2005
    281
    Tom,
    I am building one for RC models at the moment and waiting for the electronic for it. If you do a search you should find some or the Yahoo cnc foamcutters has some also to look at.
    If yours is for doing wing cores and stuff you need four steppers and preferably matched. That is why I went the purchase route. Could not get the same motors out of all the ones I tore apart.
    If you need any help I would be glad to give the little advice that I know.
    John
    Dec 2006
    53
    I've got an old plotter I could part with cheap if that would be a better platform. It handles D size sheets.
  1. CNC foam cutter
    By vcatalasan in forum CNC Wire Foam Cutter Machines
    Last Post: 01-06-2024, 07:29 AM
  2. ideas for those trying to build '3d printers'
    By vacpress in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 08-10-2019, 10:21 PM
  3. Build a cheap, SIMPLE, CnC foam cutter.
    By moreil in forum CNC Wire Foam Cutter Machines
    Last Post: 01-05-2009, 03:09 AM
  4. My first CNC! soon to be foam cutter
    By nikolatesla20 in forum CNC Wire Foam Cutter Machines
    Last Post: 08-06-2005, 07:48 PM
  5. Foam cutter
    By paulried in forum CNC Wire Foam Cutter Machines
    Last Post: 10-30-2003, 10:58 PM
