586,072 active members*
4,602 visitors online*
    Feb 2013
    5
    6061 Aluminum Rotor Hats (Turned, Drilled)
    Quantity: 2pc
    Material: 6061 or 7075 Aluminum (6061 will be cheaper, but if you have surplus 7075 stock, either will work)
    Finish: Raw
    Tolerances: +/- 0.005"/0.13mm
    Edit - I understand the tolerancing might be tight for some aspects of the design. The center bore and the 107.95 Radius that the 12 holes are on, are the two critical dimensions (as well as their concentricity). Otherwise, we can probably be a bit more open.
    Message me here, or email me ([email protected]).
    Sep 2009
    135
    Re: 6061 Aluminum Rotor Hats (Turned, Drilled)
    Quote sent
    Sent from my SM-G955U using Tapatalk
  1. 7075 bar stock turned and center drilled
    By advert in forum RFQ (Request for Quote)
    Last Post: 11-04-2016, 04:41 AM
  2. Hex Bar Stock turned and drilled/tapped
    By ez3022 in forum Employment Opportunity
    Last Post: 10-01-2010, 12:04 AM
  3. RFQ - Turned Steel w/ Drilled & Tapped Set Screws (Cancelled)
    By AuroraDrvr in forum Employment Opportunity
    Last Post: 04-14-2009, 07:12 AM
  4. Replies: 9
    Last Post: 09-12-2006, 01:26 PM
  5. RFQ - small mild steel turned and drilled parts
    By mcmmach in forum Employment Opportunity
    Last Post: 07-29-2005, 03:37 AM
