586,117 active members*
3,329 visitors online*
Results 1 to 6 of 6
    Sep 2018
    83
    Question Really silly question
    Does anyone know the name of the connector type that's used in a lot of CNC hardware - the green plugs that you screw wires into? I genuinely can't remember what they're called, and googling 'green plug screw terminal' turns up the THD screw connectors instead.
    Nov 2012
    1267
    Re: Really silly question
    Terminal block, plug-in terminal block. A colloquial name is "Phoenix terminal".
    Sep 2018
    83
    Ah, phoenix terminal - that was it. Thanks
    24221
    Green is usually reserved for the GND terminations, these automatically connect the terminal to the enclosure frame, they are also coloured green/yellow.
    These terminal types are also known as DIN rail terminals.
    Other manuf. are Weidmuller & Allen-Bradley etc.
    Al.
    Albert E.
    Jun 2011
    692
    Al, you're thinking of something different. I think the OP is referring to PCB mount terminal blocks, which very often are green, like these: https://www.digikey.com/product-deta...1585-ND/568622
    or these: https://www.digikey.com/product-deta...876-ND/1588451
    Sep 2018
    83
    skrubol, that second link is exactly what I had in mind. Thanks for finding a supplier for me
  1. Silly Question
    By wildrat in forum Machines running Mach Software
    Last Post: 09-10-2014, 07:11 AM
  2. Silly Question
    By Son of Aslan in forum Commercial CNC Wood Routers
    Last Post: 06-21-2012, 09:48 PM
  3. Silly Question
    By Smitty911 in forum Uncategorised CAD Discussion
    Last Post: 12-21-2010, 06:30 PM
  4. Silly Question
    By Smitty911 in forum CamBam
    Last Post: 02-11-2008, 10:30 AM
