586,072 active members*
4,594 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma Twin Star LT200-MY Turret alignment
    Mar 2018
    8
    We recently acquired a used Okuma Twin Star LT200-MY lathe. The B turret is out 0.01" when indicating across the tool post mounting surface using the Z axis. Does anyone have a procedure on how to adjust the alignment for this. Ive done this on many other lathes but not one like this.I cant find any jacking screws for the adjustment. Info for this machine seems to be very hard to come by.
    Jun 2015
    4154
    Re: Okuma Twin Star LT200-MY Turret alignment
    hi onyx, i don't have such a multitasking cnc, even if i wish for ... but did you strip it ? did you inspect it well ?
    depends on lathe type / brand; some lathes have screws especially for such adjustments, while other require the alignment to be done by a bit of turret pushing with a crowbar, etc
    not all have screws designed especially for adjusting the alignment
    is ok; A turret is harder to align, especially with Y spec, because it is more tilted then a regular one
    i am sorry, i can't give you exact infos, since i don't have such a cnc / kindly
    Mar 2018
    8
    I haven't indicated A yet, It cuts well and on size. B does not, tool is below center and Z inclination is out as i mentioned. I have stripped the way covers off. There are no adjustment bolts to be found. The entire Turret assembly is bolted to the 4 linear bearings directly, running on the rails for the lower carousel. Then the lower carousel is bolted directly to the Z linear bearings running on the rails mounted to the bed. I don't see where i can adjust it unless i loosen off the mounting bolts for the linear bearings. Before I do that i was hoping to find some info.
    Jun 2015
    4154
    pls wait a bit, maybe someone with experience will reply; it may happen in next few minutes, maybe a couple of days
    all i can do, is ask you for some photos, from many angles, so to have an idea about machine layout; maybe i can help ?!
    also consider contacting your local okuma rep, maybe gosiger ? maybe you will receive precious indications only after making a phone-call
    do you believe that tool will be on center after you align Z axis ? do you have Y on B turret ? kindly
  1. okuma lc40 twin turret osp5000l-g control
    By ozrams33 in forum Okuma
    Last Post: 01-13-2014, 07:57 PM
  2. okuma lc40 twin turret osp5000l-g control
    Last Post: 01-12-2014, 09:44 PM
  3. Replies: 13
    Last Post: 02-21-2011, 11:53 PM
  4. Okuma LC40 Twin Turret
    By brisbanite in forum Okuma
    Last Post: 12-14-2010, 11:18 PM
  5. okuma twin turret axis flip?
    By fishy steve in forum Okuma
    Last Post: 11-11-2010, 02:35 PM
