586,032 active members*
2,993 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA 5000L Alarm 952 Running time over. Green Screen model
    Jun 2014
    4
    Hi I have Alarm 952 on my Okuma LC40M Running time over. This alarm is not listed in the manual for 5000L but in the 5000L-G manual in the parameter section it shows these Hour meter timers which can be adjusted. Unfortunately we cannot find such pages in our contoller and hope some-one knows how to fix this problem which stops the machine being used. Thanks
    Jun 2014
    4
    Re: OKUMA 5000L Alarm 952 Running time over. Green Screen model
    Note the Alarm is 952 Alarm C Running hour over.
    Apr 2009
    1262
    No hard hour meters?
    Could also be parameter settings for STM tme over or Cycle time over. Check the bit settings on your machine. Turn them off (0) if they are on. Also check to see if the machine is waiting on some sort of answer signal that could be causing it.
    I thought on that vintage, the hour meters were not in software, but were hardware. Check for them on the electrical cabinet.
    Experience is what you get just after you needed it.
  1. Okuma LS30N green screen monitor issue.
    By rotec in forum Okuma
    Last Post: 10-19-2018, 07:02 AM
  2. Replies: 9
    Last Post: 06-04-2018, 09:54 AM
  3. Replies: 3
    Last Post: 09-25-2015, 01:52 AM
  4. Replies: 4
    Last Post: 02-02-2011, 10:43 AM
  5. BTR for Okuma OSP5000L (green screen)
    By bradleyk in forum DNC Problems and Solutions
    Last Post: 10-29-2008, 06:10 AM
