586,103 active members*
2,878 visitors online*
Results 1 to 12 of 12
    Aug 2018
    14
    can't input parameter Fanuc 0-P
    Dear all,
    I have a punch machine with Fanuc 0-P controller.
    After replace battery without power on, i have to clear memory to start machine.
    But it is strange, i only receive 2 error: 417 and 427 for X,Y digital parameter without error 100: Parameter write enable.
    So that, i turned on E-stop(ESP) switch, the screen still show "NOT READY" instead of "EMERGENCY" so i can't input Parameter enable =1 on Setting Handy page.
    And its strange, i turn on or turn off E-stop switch, bit 701.5 DGN still =1.
    And on the master PCB, SO led red and SI led green light.
    Anyone know this problem and can you help me?
    Thank for your reading and best regard.
    Attached Thumbnails Attached Thumbnails 43514607_619750455093918_8992550633122824192_n.jpg   43739495_2160470014279222_6109261919640616960_n.jpg   43828281_297278360876419_150974792013447168_n.jpg   43880663_245789902954887_4840918086691323904_n.jpg
    Mar 2013
    27
    Re: can't input parameter Fanuc 0-P
    Murata/Muratec uses switches inside the electrical cabinet to enable parameter setting and other stuff.
    Verzonden vanaf mijn iPhone met Tapatalk
    Aug 2018
    14
    Is it your mean?
    I turned on this switch.
    Today, after replaced 2 socket chip: OE1,OE2; the screen showed alarm "100: parameter enable" and on setting handy page: parameter enable =1.
    But i still can't input parameter. So sad.
    Mar 2013
    27
    Yes, thats the switch I mean. You probably lost all your parameters, so start with inputting the option parameters. They should work.
    Aug 2018
    14
    But i can't input parameter. Eg: in line N000: i type "P 11110101" then press "INPUT" button, but the screen still show "P 11110101" and N000 still 00000000
    May 2016
    526
    Quote Originally Posted by noziz View Post
    Load the option parameters first
    Why are you inputting p first
    Whereabouts are you ?
    Quote Originally Posted by mbservice View Post
    Can you tell me how to input parameter option in c3000 muratec
    Aug 2023
    11
    it gives me this error
    1019 IN PUNCH CYCLE
    May 2016
    526
    Quote Originally Posted by Adnan007 View Post
    1019 IN PUNCH CYCLE
    Please private message me
    Aug 2023
    11
    can you give me your email
    or write me privately because I can't write, I don't know why
    May 2016
    526
    Aug 2023
    11
    1037
    I/T COUPLING ALARM
  1. Mazak T2 parameter input format?
    By nervis1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-25-2023, 04:39 AM
  2. Replies: 0
    Last Post: 05-23-2011, 11:28 PM
  3. Fanuc 10M Parameter input
    By nastek in forum Fanuc
    Last Post: 10-05-2009, 10:01 PM
  4. Fanuc 7M parameter input
    By greenery_fr in forum Fanuc
    Last Post: 05-27-2009, 02:13 AM
  5. Meldas M0- cannot input xyz axis parameter
    By Place2809 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-22-2008, 05:55 PM
