586,070 active members*
3,517 visitors online*
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    May 2018
    30
    Re: tb6560 + nema 23 +grbl
    hello new fast help state a time working with a 3 axis cnc with nema23 + arduino + tb6600 all ok
    but make me another cnc with 4 motors
    2 engines go to the Y axis here is where the problem starts
    the arduino there is no pin for a 4 motor as I can enable or connect the 4 motor so that it works
    Thank you
    https://postimg.cc/4KLxkYKk
  2. #22
    Mar 2015
    410
    I think you will want the 2 steppers for the Y-axis turn at the same time, direction and speed.
    For this to work, you need a driver for each stepper motor (like in the picture).
    Connect (parallel) the step/direction/enable/+5V signals for the Y stepper driver to both the Y stepper drivers.
    Connect the 4e stepper to the 4e driver.
    Let me know if this works for you
  3. #23
    May 2018
    30
    hello forgive my ignorance can be a problem of the translator but I do not understand well
    the question that arises
  4. #24
    Mar 2015
    410
  5. #25
    Jul 2018
    87
    This is how I connect my tb6560 to my db25 bob... the yellow wire in the bottom left comes from a 5v power supply... the 5v power supply is a 5v cell phone charger which is powered by the 24v power supply
    At the top right is the - & + 24v directly from the 24v power supply.... next to that is the stepper motor wires... at the bottom i have en+ & cw+ & clk+ & 5v all connected , cw- & clk- are the two orange twisted wires which is step and direct to the bob hope this helps
    Bradley
Page 2 of 2 12
  1. Replies: 3
    Last Post: 06-03-2016, 02:48 PM
  2. GRBL Connecting Arduino UNO TB6560 Driver
    By pock in forum CNC Machine Related Electronics
    Last Post: 07-09-2014, 01:06 PM
  3. GRBL settings help with TB6560
    By scales11 in forum Stepper Motors / Drives
    Last Post: 08-22-2013, 11:54 AM
  4. TB6560 3 Axis 3A and Nema 23's I'm NEW to CNC.
    By ihacbook in forum DIY CNC Router Table Machines
    Last Post: 11-18-2012, 11:21 PM
  5. Someone please help with wiring nema 23 to TB6560 AHQ
    By coltac in forum Stepper Motors / Drives
    Last Post: 09-19-2012, 01:19 AM
