586,071 active members*
3,912 visitors online*
IndustryArena Forum > Community Club House > Environmental / Alternate Energy > question about cables on kite power generation systems
    Mar 2005
    266
    Just asking I do not develop anything... I saw on the web that kites with LONG lines can essentially tie in knots unless the lines are stabilized to prevent them from thrashing about... I have also seen on TV how support cables on bridges have been stabilized by adding a spiraling element around them to break up the wind flow that causes resonant oscillations. Now onto my Q... could kites flown using twisted steel cables be immune to any serious thrashing?
    Reason I ask even tho I will likely never build a kite power system is that I still think about it and can't decide if I should use vinyl coated cables which would nullify at least some of the twisted cables anti-thrashing effect.
    Feb 2004
    84
    Re: question about cables on kite power generation systems
    Spectra or kevlar is used for kite lines, steel would be too heavy, and it would probably be a multi line rig to orient properly.
    See my stuff for sale at http://stores.ebay.com/Industrial-Tool-and-Machine-Works?refid=store
  1. Burned Gecko G540- Power Supply or DB9 cables?
    By huh2 in forum Gecko Drives
    Last Post: 01-16-2015, 04:58 AM
  2. Using MIDI cables to power motors
    By uspl in forum CNC Machine Related Electronics
    Last Post: 02-22-2012, 07:34 AM
  3. Twisted Pair for Stepper power cables?
    By steveharr in forum CNC Machine Related Electronics
    Last Post: 05-10-2009, 04:21 AM
