586,047 active members*
3,772 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > G200 drilling with Q parameter in iso programming
    Aug 2007
    224
    This drilling cycle in iso programming format with G200 Q parameter..some my machine not accept this format even i change machine programming format from Heidenhain to iso..... when i transfer this program from pc to machine there is a error come on G200 line
    It work in iso, but in certain format only.What controller? In tnc 430 N10 G200 Q200=2 Q201=-20 Q206=150 Q202=5
    Q210=0 Q203=+0 Q204=50 Q211=0 * You need to fill all the drilling parameters in the exact same sequence, even if the value is zero. I wasted a lot of time with G83, working very similar (sequence matters, and all parameters must be filled). Hdh drill cycles in iso really sucks. I ended up with CAM software emulated drill cycles, and it works surprisingly well
    Aug 2007
    224
    Quote Originally Posted by five7 View Post
    Thanks bro for response .my controller is tnc426 (nc software 480462 08...i already used this G200 cycle with iso code on tnc 430...i use creo cad cam software for design snd cam
    What is it mean (I ended up with CAM software emulated drill cycles, and it works surprisingly well)
    Regards
    Asif
    It means, that my postprocessor give out the drilling cycle using only G0 and G1. I use Gpost. Regards
  1. holzher 7123 parameter programming
    By terry10 in forum Commercial CNC Wood Routers
    Last Post: 06-14-2016, 12:18 PM
  2. Parameter for programming tailstock
    By Captdave in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-25-2012, 09:58 AM
  3. Index G200
    By Pastaga in forum SIEMENS -> GENERAL
    Last Post: 08-21-2011, 08:17 PM
  4. Programing G200
    By automizer in forum Haas Lathes
    Last Post: 06-02-2010, 06:28 AM
  5. Programming 5-axis drilling
    By Dan B in forum Uncategorised CAM Discussion
    Last Post: 04-28-2003, 11:46 AM
