586,103 active members*
3,105 visitors online*
    Jul 2018
    87
    Help usb smooth stepper bsmce04-pp on plasma
    Greetings
    Can anyone please help, I’m attempting to wire a usb smooth stepper bsmce04-pp,for my plasma table, I got as for as getting the motors to run but no luck in setting up the limit switches as there are no PIN numbers on the board so I don’t knw what to tell mach3 on the input signal page ,does this board need to be powered as the db 25 bob? ,how do I knw where the common ground is for the limit switches? What port number do I choose?
    Help will be highly appreciated.
    Re: Help usb smooth stepper bsmce04-pp on plasma
    That's not a Smooth Stepper.
    Where did you get the board from? There's no manual?
    According to a manual from a newer version of the board, try this:
    I1 = Port 3 pin 1
    I2 = Port 3 pin 2
    I3 = Port 3 pin 3
    I4 = Port 3 pin 4
    Jul 2018
    87
    Ok I got right.... According to another pdf I found in the manual ,the port number must b 3 and after doin that ,the red reset button bottom left came to life and I am able to change active low to neutralize the reset button ,but I’m unable to trigger is via a limit switch on the board itself, I also see in one of the PDFs the board is powered with 12/24v to the 24v and DCM pins.. is it really necessary to power it?
  1. SMOOTH STEPPER
    By gabedrummin in forum SmoothStepper Motion Control
    Last Post: 07-05-2017, 01:43 PM
  2. Replies: 3
    Last Post: 08-08-2014, 02:01 AM
  3. USB smooth stepper stops when starting plasma arc
    By da_Rayman in forum SmoothStepper Motion Control
    Last Post: 05-06-2013, 05:17 AM
  4. Smooth Stepper, what do I need?
    By itko in forum SmoothStepper Motion Control
    Last Post: 02-19-2013, 10:16 PM
  5. Smooth stepper
    By dnelso in forum Charter Oak Automation Support Forum
    Last Post: 08-04-2009, 05:07 PM
