This is my first CNC project.
Yesterday I purchased from a second hand shop the X / Y table shown in enclosed pictures and a separate unit I think would make a great Z axis.
I would like to make a CNC mill out of it for maily mahining aluminum and steel.
Right now I cannot make up my mind on how to proceed.
I can see 2 possible solutions:
1. mount the Z axis onto the X/Y table and build another machining table in front of the X/Y table with the spindle mounted onto the Z axis and protruding onto the machining table.
2. Make a gantry for the Z axis and mount a machining table surface onto the X/Y table however the support is not very large consiering that the machining table may be 30" x 25".
Which way would you recomend to go and what are the issues to be considered
some additional data:
I measured the movements as follows:
X = 26"
Y = 20"
Z = 12"
for X & Y, I got 2 servo's included. They are Sanyo Denki Super U 80W, 75 V , 1.7A. Therefore I have ordered out 3 Gecko drives. But I am afraid these motors may not be strong enough for a milling application.
The servo on the Z axis was missing and I'll have to look out for one able to handle te spindle weight.
By the way, at the bottom of the Z ball screw, there is a brake mounted. It seems that it will release once 24VDC is applied to it. I haven't got 24 VDC to try but with 20 V, it did not release.
I have a DeskCNC controller waiting for this application. Not sure if it can handle suh a brake control on the Z axis.
