I have a Sieg mini Mill with an FC350BJ spindle controller. I have converted this into a complete CNC machine and converted the spindle to a belt drive. The setup I have has worked on another mill I converter. However, on the second Mill, I am having some issues with the spindle. When I supply a speed value of 3,000 or above the spindle pulses on/off. Almost as if the switch between pin 6 and 7 is clicking on/off. I have made sure the door switch between pin 6 and 7 is completely closed. A fuse has no blew because I have connected a wire directly to pin 4.
I wonder if this is an overload issue, with is triggering the spindle on/off. Is there any suggests, calibrations, or help you can give for this issue?
Thank you in advance!
