586,103 active members*
3,438 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > RF-45 Clone Mill > Gear drive to higher spindle speed belt drive - are kits available?
    Oct 2018
    79
    As the title I'm looking at buying a 2nd hand geared PM-45 type machine but woudl like to a) make it quieter and B) increase spindle speed for CNC
    Are bolt on kits available - any links?
    May 2008
    1185
    Re: Gear drive to higher spindle speed belt drive - are kits available?
    I made some in the past but I'm not doing them right now.
    The simple way is to remove the gear spindle drive cut the gear off and weld on a flange for the pulley.
    youtube videos of the G0704 under the name arizonavideo99
  1. I.H. Belt drive conversion spindle drive sleeve gear
    By Roadstercycle in forum RF-45 Clone Mill
    Last Post: 04-23-2018, 12:43 AM
  2. Which is good drive system belt drive or gear druve
    By M.Abid in forum Excitech routers
    Last Post: 12-14-2014, 04:13 PM
  3. Belt & gear drive for servo's?
    By LUCKY13 in forum Uncategorised MetalWorking Machines
    Last Post: 10-28-2011, 06:59 AM
  4. Gear/Belt drive shotptask
    By leeharrysouth in forum Shopmaster/Shoptask
    Last Post: 03-18-2010, 10:38 PM
  5. belt drive VS gear conversion?
    By eartaker in forum Benchtop Machines
    Last Post: 12-25-2009, 04:00 PM
