586,080 active members*
3,442 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang VFD to RS485 issue
Results 1 to 8 of 8
    Apr 2009
    9
    Hi hi to all concerned, I've a VFD issue. Md# HY02D223B 220v 2.2k
    With no output to the spindle, the inverter is powering up and running as normal but it is not accepting any info from the rs485 dangle.
    I swapped the drive board (the one with the single small blue relay & green connecting tag strips) with another similar board and everything works well.
    Does any one have or had similar problems or know what's the cause I'll be very thankful for any advice.
    If repairs is a no no and someone have the board in question in working condition from a similar broken VFD and wouldn't mind parting with same can contact me at [email protected] .
    Thanking you all in advance.
    Best regards.
    24221
    Re: Huanyang VFD to RS485 issue
    Are you using the Mach 3 plug in?
    Is this a USB to RS485 convertor?
    Al.
    Albert E.
    I don't think anyone knows what you are talking about ?????????
    Apr 2009
    9
    Yes I'm using the plugin and yes I'm using the rs485.
    The machine is back up and running right now with a drive board (module) I borrowed from another VFD, so I know that the problem is the particular drive or control board I mentioned earlier.
    The original VFD is still working because I swapped the part from another VFD.
    So I need to repair or replace that particular board in order to have both VFD operational.
    Regards.
    Apr 2009
    9
    Al.
    This is the faulty board.
    Sent from my SM-G570M using Tapatalk
    Apr 2009
    9
    Hi Al_The_Man.
    I just sent you a picture of the board, I'm not on base at the moment I'm on mobile should be back on base in a couple hours.
    Regards.
    15362
    Quote Originally Posted by webman_tt View Post
    Hi Al_The_Man.
    Regards.
    I did have some of those boards, but they have all been used, there are most likely lots around from failed drives, your other choice is to contact HY direct and they may be able to send you a new board, or just buy the cheapest HY drive and get the board out of it, make sure it is an HY Drive if you do buy another one as there are copies out there that are not the same
    Mactec54
    Apr 2009
    9
    Hi mactec,
    I believe some one in the forum may have one of these unit where the Power output section is broken but the Control stage is fine and would'nt mind parting with same.
    Please note its just a Thought:wave:.
    At present my country is under serious water the worst in it's none history.
    Sorry I had to cut short my discussion so promply with 'Al' and 'Ger' yesterday, I had to go help the needy (It all part of the word called 'L-I-F-E').
    Take care now Mactec.
    Regards.
  1. Huanyang VFD RS485 / Modbus
    By scotta in forum Phase Converters
    Last Post: 05-15-2022, 03:13 PM
  2. Huanyang VFD Issue pot not going past 25hz.
    By gomviandres in forum Spindles / VFD
    Last Post: 10-10-2018, 08:29 PM
  3. Huanyang VFD RS485 issue
    By shipmodeller in forum Spindles / VFD
    Last Post: 10-01-2018, 12:30 PM
  4. RS485 commands for Huanyang VFD (HY02D223B)
    By bouni in forum Spindles / VFD
    Last Post: 05-07-2015, 04:32 PM
  5. rs-232 and rs485 bus
    By eloid in forum Mach Software (ArtSoft software)
    Last Post: 03-13-2007, 04:39 AM
