586,069 active members*
3,554 visitors online*
IndustryArena Forum > Community Club House > Machinist Hangout > 8 mm straight flute feed ,speed and doc on plyboard
Results 1 to 6 of 6
    Apr 2017
    20
    Hello friends can anyone help me out to slecting feed ,speed ,doc for a 8 mm straight two flute on plyboard of 25 mm thick made of hardwood ....please help me any information will be walcome
    Sent from my Moto G (5S) Plus using Tapatalk
    Re: 8 mm straight flute feed ,speed and doc on plyboard
    Is that carbide tipped, or HSS?
    It really depends on what your machine is capable of.
    Anywhere from 10,000 rpm and 100ipm to 18,000 rpm and 300ipm.
    Assuming the bit is new and/or sharp.
    Apr 2017
    20
    It's a solid carbide 8mm bit and I have a 3hp spindle
    Apr 2017
    20
    Hello
    Ger21 ... thanks for answering ...yes it's a solid carbide bits ...it's flute langth is 35 mm and it's a 8 mm diameter two flute straight bit ...
    And I'm cutting a bwr (boiling water resistant) plywood of 25 mm thickness
    And I have a 4x8 table cnc with 3 hp spindle which can go 18000 rpm and machine can go to 500 ipm....
    Well I tried it today on plyboard with these specifications ....
    Feed ...118 ipm
    Spindle ....10000 rpm
    Doc .... 5
    Opretion ....slotting 25 mm plywood
    Problem .....the tip of tool has visible black mark ..it heated up at tip
    And it sounds very crazy when cut
    Note ...I checked tool is ok it's new sharp and strong ...it heated up but still it's flute are not burned ..
    Please suggest me ...welcome for all
    Aug 2014
    232
    Spiral bits work much better, especially the serrated "ripper" type. I would use an upcut ripper if you can secure the work well. If you need a good finish, you can do a full depth finishing cut with a compression bit.
    Jul 2016
    660
    I use this on a daily basis on a hardwood, 24,000 RPM @ 2000mm/min, it can even cut aluminum and mild steel, on a hardwood a 5mm step per pass is very safe enough, you can run it all day on a 5 pass 25mm hardwood.I run it @ 1mm per pass because our products are very small
  1. Straight flute - birch ply
    By Jon.N.CNC in forum Material Machining Solutions
    Last Post: 05-25-2016, 04:49 PM
  2. Speed on 1/8 Carbide Straight flute Drill on 404 Stainless
    By anrsh2 in forum MetalWork Discussion
    Last Post: 08-02-2014, 04:25 PM
  3. PCD Single Edge Straight Flute Polishing Tool for Acrylics
    By CNCRouterStore in forum News Announcements
    Last Post: 02-26-2014, 05:37 PM
  4. Straight Flute End Mills
    By shearder in forum CNC Tooling
    Last Post: 02-06-2014, 11:32 AM
