586,065 active members*
4,327 visitors online*
    Question Uneven cuts, 1/4" off
    I have a shop sabre IS series. I have noticed that I don't have the sharp edges on fiberboard that we used to have. One chair will be fine, but the one next to it will be off.
    I did notice the router spindle was loose, so we tightened it up. But we have to keep tightening it up every other day. I have not checked other bolts, but I will monday morning.
    Also, noticed the boards are always off on the X axis at least 1/8 off to sometimes a half inches off. Had Ben get in the computer and he seemed to fix it for that one day, but it's doing it again!
    Re: Uneven cuts, 1/4" off
    1) Use blue Loctite.
    2) What did he do to fix it?
    I will tell Maintance man to put some loctite on it.
    I honestly don't know what Ben did, he got in the team viewer and changed a dimension setting for the x axis I believe. I will pay attention next time I call him this week.
    Lisa_jenson1982 Guest
    I ended up calling Shop Sabre and Ben got into the Win CNC file and changed the x axis demention....and it fixed the measurements,
  1. 60W Laser Engraver Does not cuts uneven way in x axis
    By cdmc in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-28-2018, 06:57 PM
  2. Deeper and slower cuts for "weak" cnc router?
    By KING2882000 in forum Autodesk CAM
    Last Post: 10-12-2017, 10:17 AM
  3. Uneven Cuts
    By mpa542 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-21-2015, 09:22 AM
  4. P-Max 85 1 1/4" cuts
    By BBchevy396_ in forum Hypertherm Plasma
    Last Post: 05-06-2011, 03:47 PM
  5. "Cheap" CNC Mill that cuts steel?
    By parcheezy in forum Open Source CNC Machine Designs
    Last Post: 09-02-2010, 06:23 PM
