Hi guys - does anyone have a picture of a correctly installed X-1 gear selector fork in place? I have broken two in as many weeks, and I can't tell from the instructions which way round it should go - it isn't quite symmetrical.
Also has anyone made their own replacement one? I'm not convinced that the horizontal slot that engages with the pin on the gear-selector knob is an ideal shape for a smooth gear-change - wouldn't some sort of arc work better to turn the rotary motion of the knob into a vertical movement of the fork and gears?
Cheers.
P.S. The part I'm referring to is #43, I think - it's the curved metal piece that clamps the high and low speed gears and drags them up and down their shaft.
