586,068 active members*
4,417 visitors online*
Page 1 of 2 12
Results 1 to 20 of 22
    Mar 2012
    150
    Precision high resolution machine build
    I'm looking for 1um in 500mm resolution and also accuraries in the order of 1um.
    What does it take to achieve this.
    I was looking for a 3 axis gantry type build, with 500mm x 500mm work area, is that the way to go?
    I have read this forum post exhaustively https://www.cnczone.com/forums/linea...60578-cnc.html
    And from what I gather from that post the minimum requirements are
    1. C1 / C3 ground ball screw with 3mm lead.
    2. Ultra precise encoder 24bit+
    3. AC Servo motors or Linear motors
    4. Good air conditioning
    5. Good measuring equipment
    Also I have read user hanermo's post https://www.cnczone.com/forums/linea...ml#post1656188 and he gives quite interesting advice.
    I have a few questions
    1. Can I get away with C7 rolled ball screw, my thinking is with ultra precise encoder and servo's and maybe a optical linear scale, the controller should be able to accurately position itself even though the screw is inaccurate?
    2. Can I get a off the shelf gantry structure with decent accuracy so that will speed up my build.
    3. For encoder/ linear scale Renishaw Resolute what kind of price range does one expect?
    4. Servors DMM ac servo's ok? I mean with their integrated 16bit encoders? Can steppers do the job, by running it in closed loop mode?
    5. What kind of motion controller / software would I need for achiving these accuracies?
    6. How does the optical linear scale work in conjunction with the integrated servo encoders? I mean does the optical linear scale output go in seperately to the motion controller, and then some software needs to be written for closed loop control?
    Thanks in advance
    15362
    Re: Precision high resolution machine build
    Quote Originally Posted by ZeroBacklash View Post
    Thanks in advance
    If you are serious then a linear motor would be the easiest way to achieve this, I have some that do +/- 1um at 2G
    C7 Rolled Ballscrew never going to happen
    Steppers not possible no matter what you use
    Dmm they do have some other Encoders they are working on, this could be possible if everything else is used Precision Grade Linear Rails C1 Ballscrews all built on Granite
    It gets very complicated when you want duel control of both linear and rotary Encoders which is not necessary when you use a C1 or C3 Ballscrew you would achieve very little by having Linear scales, plus to have a Linear scale with that accuracy would cost more money than the whole machine build
    Mactec54
    Mar 2012
    150
    What brand is that, what costs are we looking at for a +/-1um? and what is 2G?
    Why is a C7 ballscrew bad, when we have precision servo's with precision encoder. What could go wrong ? and where?
    why? and why would closed loop steppers not achieve this kind of accuracy, repeatability etc. is it due to the inherent construction of the stepper motor?
    If not DMM then what would you suggest?
    Ok so you are saying either use the rotary mounted encoder or a glass scale encoder. Using both could leed to complications. correct? What is the best way an encoder mounted on the axis on an encoder mounted on the motor?
    15362
    I would say you need to do some research and figure some of this out some of the basic's for your self, you are just wasting peoples time with these questions
    C7 Ballscrews and closed loop steppers not sure why you would be even asking that question 1um
    For servos other than Dmm Yaskawa sigma 7
    Linear motor all the major manufactures make them
    Mactec54
    Aug 2004
    780
    1 um resolution is easy. ish.
    Accuracy of about 1 um is potentially easy if your motion controller system supports mapped screws and optical glass scales. ish.
    In both cases you need very rigid screws.
    For example my current lathe revisit is going on to servo direct drive, and a 32/5 mm screw. For 270 mm motion.
    And 25 mm hiwin linear guides, heavy preload.
    At issue is not the strength of the guides but the rigidity and repeatability of the system.
    A 32 mm screw is 54 kg of force, per micron, in yield error.
    My screw is C7 from TBI.
    There is probably about 0.05 mm in positioning error, max, in the screw.
    So no-where near single microns.
    But because the screw is extremely rigid, and the linear movement is extremely rigid I get excellent repeatability.
    So small incremental movements of 1 micron are 100% reliable.
    External measurement via 1 micron micrometers and 1 micron electronic dtis proves mechanical resolution and movement.
    So I can cut 1 micron steps into a workpiece I have measured with digital 1 micron micrometers.
    Past:
    But I could not, with 3/4 inch rolled roton ballscrew, and a 30 mm wide HTD8/30 1:2 drive get reliable repeatable results from the whole system running cnc from gcode without manual intervention.
    Aug 2004
    780
    Steppers are inherently inaccurate to about 1/2 of one step == 400 / turn.
    They get increasingly springy as the resolution goes to smaller angular movements.
    A stepper at 1/10 microstep has about 1/10 the torque at stall, iirc.
    So a 3Nm stepper has 0.3 Nm for 1/2000 angular movement.
    A 3 Nm (cont) ac servo, like on my lathe, has 9 Nm peak torque at 10.000 counts/rev.
    So it is about 5x more accurate, at about 10x more torque vs the stepper at 10 microsteps.
    Another good way to look at it is acceleration.
    At 68 V a Nema 23 3Nm stepper gets to 3000 rpm in about 0.5-1 sec using a good hw pulse engine. A bigger nema 34 stepper is slower.
    A Nema 34 servo gets to 3000 rpm in 20 ms or 0.02 secs.
    Once You get to 1 micron repeatability, and 1 micron mechanical resolution reliably, it is not hard to map out or adjust thermal effects.
    Simply running flood coolant a few degrees above ambient will get you a steady temperature.
    Simply probing tooltips against a fixed probe will get you submicron wear offsets.
    I am using a csmio-ip-s controller on machx sw.
    It is quite expensive, all-in, and the 750W ac servos and 32 mm D screws are not cheap.
    At some point I will add in glass scales, hopefully at 0.1 microns, for feedback.
    I have 3 points.
    It is not hard to make a 1 micron incremental movement reliably from your current tooltip position or controlled point.
    My old steppers, 1:3 HTD 5/18 belt drives, did this, 10 years ago.
    It is quite hard to get reliable repeatable positioning within +/- 1 micron.
    Not accuracy, just repeatability.
    This needs about 2-10x the 1 micron resolution desired, from the motion control system and very high push force and very high rigidity and linearity.
    It is quite hard to map screws or feedback glass scale positioning to the motion control train.
    Mar 2012
    150
    Quote Originally Posted by hanermo View Post
    What kind of motion controller will support that , I currently have a UC400ETH from CNCDrive is that good enough?
    Can't this kind of error with wiped out with the electronic positioning system. I'm still not getting why we need highly accurate screws. When the encoder + servo can map the movement. I mean when I say go x10.003, y20.005 won't the controller do the necssary jugglery to reach there. as long as the encoder is not given it a feedback the I have reached to target the servo will try to achieve the target position.
    Btw do all modern software operate down to 1um, I mean can I say in gcode go to 0.001 and it will move to that position?
    When we talk of ball screws. Is c0 to c5 ground version and c7 onwards are rolled versions. because that was the impression i got when i read the THK catalogue.
    Mar 2012
    150
    I have 3 points.
    Many thanks Hanermo this is very useful, and highly appreciated.
    If I'm getting you correct if I need a +/-1 um reapeatable position, would i need 0.1um glass scales? I see that the typical scales that we get is 5um with a 20um grating pitch and you also get 1um with 20um pitch by paying a bit extra.
    Like I said earlier I still don't understand who is responsible for the repeatable accuracy. I thought its solely the electronic system, servos + controller + encoder. I still don't get what part does the screw have to play in getting a precise position?
    What kind of recommended part list would you suggest for this system. I don't have much load on the axis I will just be mounting a laser, so there are not much forces on the system.
    Mar 2012
    150
    Thanks for the suggestions, truly appreciate it.
    Jun 2010
    4256
    A lot of properly aged cast iron, some very expensive ball screws OR some very expensive linear glass scales, and $100k - $200k to put it all together.
    You will also need to air condition the workshop to 1 C and temp stabilise the cast iron to <1 C (embedded cooling water pipes).
    Which is a warning signal at about 120 db.
    Cheers
    Roger
    PS: Resolution of <1 um is not hard (my machine does that), but accuracy is another matter.
    No.
    I think LinuxCNC can do it.
    Possibly the KFLOP and KMotion?
    Other than that, you'd probably be looking at $5000-$10000 for a control that can do it.
    This project is far more complex (and costly) than you think. If it was so easy, others would have done it.
    Aug 2004
    780
    Cslabs controllers like the csmpio-ip-s I use on lathe supports secondary feedback via glass scales.
    My lathe has C axis, x, z, for now and the B axis (tailstock) and live tooling are coming.
    No.
    Jun 2011
    692
    What are the speeds, acceleration's and forces needed? If the speeds and acceleration's are low, using secondary measurement is much easier, as the feedback loop will be easier to tune satisfactorily (has more time to settle.) C7 screws might work if you don't mind going very slowly. I'm not sure why you don't want to go to at least C5 ground screws, their cost won't be much compared to the scales, linears and frame.
    Will there be any forces (other than acceleration and friction) on the movement? Machine mass needs to go way up if there are (think tons.)
    Mar 2015
    410
    Are you sure the laser beam it self is that accurate, most times laser beams aren't round but oval!
    During direction changes there is acceleration and deceleration resulting in X and Y forces on the gantry. To avoid deflection, the gantry setup must be incredible rigid and free from play! I think that even lubrication will spoil the result.
    Have you considered how to measure the finished products and how expensive these measurement tools are?
    Great respect if you can do this.
    Mar 2012
    150
    Quote Originally Posted by skrubol View Post
    what is secondary measurement?.
    I have no problem in going for the C5 ground screws, I was just trying to understand why a decent ball screw like C7 which is considered as better than Acme thread wouldn't make the cut and I was banking on the electronic systems to bail me out.
    Last i found they were around US200 for a 400mm length and C3 were around USD500 for 500mm length on Aliexpress.
    No not much forces on the axis apart from what you are saying and speed I would be happy with 100mm / sec,
    Any idea where i would get a prebuilt gantry so I can accelerate the build .
    I believe that you need to use screw mapping. You can't just use a screw with poor accuracy and expect the scales to fix the error.
    Screw mapping would require you to measure the actual distance traveled along it's entire length.
    Mar 2012
    150
    Quote Originally Posted by hfjbuis View Post
    Exactly, that was my intention of this question to understand what kind of tools, equipment, actuators and sensors are required to get this kind of job done.
    I'm open to any kind of suggestions..
    I do understand now the importance of system rigidity. I hope the esteemed folks here will highlight more issues so i can focus attention on these.
    Mar 2012
    150
    No.
    Yes, I guess I read about it yesterday somewhere on these forum's. Hopefully Kflop / Kmotion has the screw mapping feature built into it.
    Nov 2018
    Thanks in advance
    1. No & Why would you be trying to cut corners it will just make the job harder. Don't forget you are going to have to map the screws.
    2. No You may be able to get an off the shelf gantry from China But you will probably need to regrind it.
    3. $5K per axis
    4. DMM's are 16bit so if they can provide that in positional accuracy then they should be fine. 3mm/65535 = 0.0000457 this should be enough for mapped screws.
    5. Personally I would use a FPGA to control the positions of the machine I'm not sure software alone could hold this kind of accuracy at any kind of useful speed.
    6. They are just a secondary check to ensure nothing has gone wrong with the Servo's & temperature compensation is working.
    You will also need a coolant filter & chiller. You will also need to monitor the component temperature & compensate for the differences between the expansion/shrinkage of the components material & the machines.
    Having said all of that I worked to 0.0001" On a thin walled 36" casing 30 years ago on an old NC VTL.
    If you are working to tight limits you are are going to need to check dimensional accuracy mid program & compensate for tool wear.
    Good luck
    Dec 2013
    5717
    I would go with DMM servos, a Galil motion controller (40x0, or 18x6 series), Renishaw or Ditron magnetic scales or your choice of glass scales, 0.1um. I have had good luck with that combination. Properly tuned it will hit +/- 1 encoder pulse every time, normally 0
    Given the small working area, a used CMM with dead controls and a granite base would make a great machine frame. Would also include precision ball screws.
    By using the scales as the encoder input, you close the loop at the controller and that turns the servo drive into a slave to the controller rather than using the drive's intelligence. Doing it this way automatically compensates for any leadscrew error or backlash and gives you a true position.
    The one thing that is not clear to me is the end use of the system. Router? Milling machine? CMM?
    Jim Dawson
    Sandy, Oregon, USA
Page 1 of 2 12
  1. New Machine Build High Precision Fiber Laser Cutter
    By mshamber in forum Fiber Laser Cutting Topics
    Last Post: 08-31-2018, 01:02 PM
  2. high precision cnc router machine with atc
    By Rapid-monica in forum DIY CNC Router Table Machines
    Last Post: 11-01-2017, 05:11 AM
  3. Replies: 0
    Last Post: 07-04-2016, 02:55 AM
  4. high precision mini cnc machine
    By RUNNINGKID in forum Benchtop Machines
    Last Post: 02-06-2009, 11:15 AM
