586,114 active members*
3,337 visitors online*
Results 1 to 11 of 11
    Aug 2014
    24
    Question Cw-3000 Chiller enough for 80W Machine?
    Hello there guys, I have been using Ice for years... Tons of ice, More ice than water. And I pump the water out every so often to make the ice last, since I am cutting 8 hours per day +. I have never had a problem with laser power, I replace the tube once on my 50W cutter.
    I do get condenssation and I have been reading it's bad?
    Is it really bad to get condensation on the tube?
    Well, now, I have a 80W machine. Should I continue to use Ice? Or will this chiller be enough?
    I read somewhere this chiller is crap, But I would like your opinion please.
    I want to take better care of my 80W, the laser tube is like double the price, and I want it to last as long as my 50W is lasting.
    ***Note, I cut at 15 to 19% power only, but with the bigger work area on the new machine, I want to experience cutting some thicker materials etc.
    Thanks guys, have a great day.
    Sep 2018
    83
    Re: Cw-3000 Chiller enough for 80W Machine?
    What sort of temperature range are you working in? I never found anything more than a chiller to be necessary - ice sounds like total overkill to me. Set the chiller to keep the water somwhere between 14 and 18 celcius, and I don't see any reason why the tube would fail in a hurry. I ran three 90W machines 8 hours a day for years with that arrangement, and never had a tube failure. This included cutting at the full power range, from 15% for light engraving, right through to 100% at <15mm/s for thick acrylic and plywood.
    Jan 2008
    940
    If you want a real chiller move up to a CW 5000 or CW 5200 the CW 3000 is just a radiator that a fan blows across so it will never get below the temp in your shop
    Aug 2014
    24
    Thank you for the response guys. This really helped, I never knew the cw 3000 wasnt refrigerated. I would never install this cooler on my machine lol, these tubes can get pretty hot when you are running them all day every day.
    The shop stays at 65F~100F depending in weather.
    I wanted a chiller, because adding ice, removing water from bucket due to the ice melting and creating more water, opening and closing the bucket, dust gets in there, etc etc etc. A chiller would save me a bunch of time.
    I will go with the cw 5000 ! Healthy tube, happy tube !
    Mar 2016
    94
    hi
    if you can get one go for the cw 5200
    they are both the same kit but the 5200 has a biult in gas re charge nipple where the 5000 does not
    Dave
    Aug 2014
    24
    Ohhhh wow, thank you. I will certainly keep that in mind. That way in the future if I have a problem I dont have to suffer trying to braze a mickey mouse fitting on the cw 5000
    Jan 2008
    940
    How many times do you have to recharge your refrigerator.
    Mar 2016
    94
    Hopefully never but its nice to know it can be done easily should it need to be done
    Nov 2008
    643
    I’m using a 5200 on a 50W tube and it has no problems keeping up. I was using a 5000 with ice and went thru a lot of ice. I try to hold it to 16 degrees.
    The 5200 is a solid unit.
    Jan 2008
    940
    I run a cw 5000 on my 130 watt laser with no problems
    If you run the equipment all day, CW-3000 is not enough, please choose CW-5000 chiller
  1. The selection for chiller of laser cutting machine
    By AngelaYXH in forum CNC Machining Centers
    Last Post: 10-15-2018, 03:52 AM
  2. Chiller Flushing Kit For Your Laser Machine
    By mglaser112 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-25-2018, 07:09 AM
  3. Water Chiller CW-3000 ....Beeping
    By cdesigns in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-23-2016, 10:50 PM
  4. CW 3000 Chiller Alarm Wont Stop, need some help please
    By jmstapp8 in forum USA Club House
    Last Post: 08-24-2015, 03:20 PM
  5. USD350--Water chiller CW5000 for 60w-100W CO2 laser machine
    By Sino-waterjet in forum News Announcements
    Last Post: 05-12-2014, 09:46 AM
