587,033 active members*
3,405 visitors online*
    Mar 2007
    3
    Help with mazak g-code
    What is the format for the G10 on a Mazak lathe?
    Dec 2003
    24223
    What control? Mazak use Mitsubishi, Fanuc, Yasnac.
    Al.
    Albert E.
    Dec 2003
    24223
    OK Mazak predominatly used Mitsubishi, if you need a manual, look for a system number on the top of the controller rack, like M300,M550, M50 etc,
    Go to the MEAU site and download the operator manual.
    If it is a Fanuc 0, I can send it in PDF.
    Al.
    Albert E.
    Apr 2006
    3206
    For a 640T:
    G10 L10--Programmed Tool Offest Input
    G10 L10 P_X_(U_)Z_(W_)Y_(V_)R_(C_)Q_;
    P offest #
    X x axis offset , absolute
    U x axis offset, incremental
    Z z axis offest, absolute
    W z axis offset, incr.
    Y y axis offset, abs
    V y axis offset, incr.
    R tool nose rad comp amount , abs.
    C tool nose rad comp amount, incr.
    Q Hypothetical tool nose point
    L value is optional
    G11 cancels
  1. Text file with NC code - what's needed so that Mazak can run this?
    By kevotron in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-08-2007, 09:45 PM
  2. g code mazak
    By robs_96 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-16-2006, 08:17 PM
  3. Mazak Program Rotation Code?
    By Cascade Dave in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-27-2006, 08:22 PM
  4. Mazak alarm code 323. Need help please.
    By RMagnusson in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-20-2006, 10:05 PM
