586,060 active members*
4,185 visitors online*
Page 3 of 6 12345
Results 41 to 60 of 119
  1. #41
    Oct 2018
    98
    Re: 60" x 40" new build
    My build was taking up too much of my workspace at work, so i have taken it home to finish.
    Last week i was given a lincoln 275 square wave tig machine and i sent the control board out for repair and I've hunting down tig accessories.
    New ballscrews came in. I think i have their location figured out now. My controller box is almost done.
    Hurry up and wait....
  2. #42
    15362
    Quote Originally Posted by Jdubya View Post
    Looks like i can swap out the 1605's for 2005's if my long axis is too slow for a few hundred bucks if needed to gain more RPM's. Are 2005's big enough for that 60" length @ Skrubol for higher rpm's?
    Your screw pitch is where you can gain speed 2005 is 5mm pitch this 5mm pitch is normally used for the z axes if you are going to change them get 10mm pitch screws 2010 ballscrews this will double your machine speed with the same RPM
    Mactec54
  3. #43
    Oct 2018
    98
    Thanks, i did replace the long axis 1605 screws with 2010 screws after all.
  4. #44
    Oct 2018
    98
    I would have used 4" ibeam looking back now so the 2010 ball screw bearing blocks would have fit very cleanly inside the ibeam but this will have to do for now.
  5. #45
    Oct 2018
    98
    Got my welder repaired but I need to grab some argon from work. Made some aluminum parts. The uprights came out pretty well. It's as square as i can make it anyways. Sure moves nice and is solid even with only 4 top screws holding it together. Ready for the backplate now.
  6. #46
    Oct 2018
    98
    Getting close to finishing my Y axis. It's boxed in anyways. Now i can start laying out my X axis.
  7. #47
    Oct 2018
    98
    X axis getting close.
  8. #48
    Oct 2018
    98
    640oz nema 34 with 1610 ball screw for the x axis.
  9. #49
    ericks Guest
    Looking good!
  10. #50
    Oct 2018
    98
    Thanks! This has been much harder than I anticipated. Lol. Free time is rare..
  11. #51
    ericks Guest
    I agree!!
  12. #52
    Oct 2018
    98
    Curious about wiring this box to the motors, i found some 18awg ingus chainflex 4) wire but its not shielded..
    Then i have some shielded 18awg but it not real flexable.
    Is there shieded chainflex? Thoughts?
  13. #53
    15362
    Chainflex type cable is only needed for any cables that are in your cable tray outside your cabinet, Shielded for motors cables and spindle to VFD, inside your cabinet you can use Twisted pairs
    Twist your cable like this, you can get in any color from McMaster-Carr
    Mactec54
  14. #54
    Oct 2018
    98
    Thank you! That helps.
  15. #55
    Jdubya Guest
    Y axis motor mounts cut and tacked in place.
  16. #56
    Oct 2018
    98
    Getting my Z axis motor mount design figured out. My spindle is about 1/4" off of center to my gantry on the long Y axis.. I think i can live with it anyways. I can see light at the end of this tunnel..
  17. #57
    Oct 2018
    98
    Z motor mounts
  18. #58
    Oct 2018
    98
    Spindle is mounted. All the way down on Z is right at the top of where my table will be. Perfect!.
    Ready to wire after i add a few more bolts.
  19. #59
    Oct 2018
    98
    For ess wiring question, one of these drawings must be wrong?
    I want to use grounds right? One pic sends 5v to each driver pul and dir. Thats not right is it?
    The second picture seems right.
  20. #60
    Oct 2018
    98
    I guess i will just try it, one way. If it does not work, ill try it the other way. Hmm
Page 3 of 6 12345
  1. Mark's EPOXY Granite 18"x20"x20" (700mmx780mmx780mm) vertical mill build
    By gt40 in forum Vertical Mill, Lathe Project Log
    Last Post: 01-19-2019, 09:26 PM
  2. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  3. New Free CNC Router Plans 12" X 11" x 4", Build for $220 or $105
    By Modular CNC in forum Open Source CNC Machine Designs
    Last Post: 11-25-2013, 12:57 PM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. First build 8020 60"x24"x5" Board Shaper
    By dlyork in forum DIY CNC Router Table Machines
    Last Post: 09-07-2010, 02:32 PM
