586,082 active members*
3,772 visitors online*
Page 4 of 6 23456
Results 61 to 80 of 119
  1. #61
    Oct 2018
    98
    Re: 60" x 40" new build
    I got it all working, well i have one driver that wont fire but the rest is working. Whew.
  2. #62
    Oct 2018
    98
    I found a chunk of wire insulation that slipped under my gantry and was stalling the motor tripping the red light on the driver. Pretty happy with the x and y axis speeds. Thanks for your help Ger.
  3. #63
    Oct 2018
    98
  4. #64
    Oct 2018
    98
    If anyone has a clue on how i should connect my spindle/vfd to the ESS so i can control the spindle from mach3?
    I know i want to use FOR & DCM and V1 & ACM , but not clear where to connect on the ESS? I have a few bobs, but not sure if i even need one.
  5. #65
    Your CNC looks very good. I am planning to build my first CNC router following a similar design.
    Is there a particular reason to use an aluminum plate for the gantry ? I can ask a friend to cut a thick steel plate for the gantry with an industrial CNC Plasma cutter. Is there any advantage to use steel? Is it going to be too heavy for this application ?
  6. #66
    Oct 2018
    98
    Quote Originally Posted by bikesherpa View Post
    Thank you. I just completed my first dry run,
    Its been 5 years since ive done that. .
    I used aluminum because we have alot of scrap laying around and it was all free. I dont know enough about this stuff to answer your weight question like others can. but some guys do use granite blocks so id guess weight is not too much of an issue? Thanks.!
  7. #67
    Oct 2018
    98
    First cut
    https://www.*****ute.com/video/BFgSTNbZXKD7/
    https://kek.gg/u/6y5t
    Its "bit chute" not "***** ute" lol
  8. #68
    Oct 2018
    98
    Still trying to understand exactly how to get mach3 to control my huanyang 400hz vfd. Not a big deal, but its a challenge now.. Im looking at trying this C41 board.
    https://cnc4pc.com/c41s-pwm-variable...rol-board.html
    None of my bobs have any relays and i think my ess c25 board needs a relay. Not sure yet. .
    Im in over my head with the electronics part, but thats never stopped me before. Ill keep reading. I have not let the smoke out yet.
  9. #69
    Mar 2019
    Kişisel hesabınız için ürünlerimizden faydalanmak istiyorsanız başta da belirttiğimiz gibi bu size daha geniş bir kitleye hitap etme ayrıcalığı sağlayacaktır. Ayrıca fenomenliğe giden yola ilk adımınızı da atmış olacaksınız.
    https://instagramdeposu.com/
  10. #70
    Oct 2018
    98
    Shields up!
  11. #71
    Oct 2018
    98
    Testing endmills.
  12. #72
    Oct 2018
    98
    Finally figured out how to set up my machine home, g54 position and got all the soft limits set and working great.
    I had some issues with a large cut growing in size by the end of the cut like i was gaining a half inch or so. Seemed like it might be related to the multicore prossesor and switching the device to standard pc was supposed to be the fix but i lost all the drivers and spent a week trying to get the xp network to load again but xp.. argg... .
    Finally set up a windows 7 laptop and rebuilt the mach 3 setting there. Still testing but so far so good.
  13. #73
    Oct 2018
    98
    Quote Originally Posted by Jdubya View Post
    Still having some issue with my soft limits. If I go to the min 0 far left and then travel to the max limit and then back to zero, the x axis keeps getting closer to my gantry. I will play with motor tuning.
  14. #74
    Oct 2018
    98
    So as i hit the max limit on the right, the motor ramps down and stops, but the numbers in x axis keep moving the last .100 or so. This is where it grows. . Hmmm
  15. #75
    Oct 2018
    98
    I am definatly losing steps in the + direction on the x axis. I swapped out the driver and its still doing it.
    If i hit the x+ really lightly, the machine coordinates move but the motor wont. X- key seems to work fine.
  16. #76
    Oct 2018
    98
    I figured it out. I bought an ebay pendant to try. Thats when i noticed the problem. Even though i turned off that driver pluggin and unplugged the unit, the driver reloads. Once deleted, it works fine again. .
    Can anyone recommend a good pendant?
    Edit: actually scratch that. If I y+ then z+, i then miss steps on x+. But if I y-, then z+, my x works fine. What the heck...
  17. #77
    Oct 2018
    98
    finally fixed my machine. I took off the add on terminal board off my ESS board and wired a 26 pin plug from port 1 of my ESS directly to my drivers. Pendant works as it should, soft limits and homing all work again, no more losing steps. No more crashing... . Yay!!!
  18. #78
    Oct 2018
    98
    Machine is still working perfectly. I took apart an old dayton 2 axis vise and used the top part as a low profile vise.
  19. #79
    Oct 2018
    98
    Howdy all!
    Its been a while since ive posted. I have been focusing on learning fusion360 the last few months. Im getting to where i can draw what i need to keep moving forward.
    I decided to try and push my machine on some steel since it does ok with aluminum.
    I am not a machinist so I am still learning what works and what doesn't the hard way.
    A quick test vid of a 1/4" endmill making .200" depth passes. I tried .400" full depth cut but it was too much chatter for my little spindle/machine.
    https://youtu.be/NXnBDVfDWNI
  20. #80
    Oct 2018
    98
    Childhood dreams coming true.
    Attached Thumbnails Attached Thumbnails 20191006_174644.jpg   20191006_174650.jpg
Page 4 of 6 23456
  1. Mark's EPOXY Granite 18"x20"x20" (700mmx780mmx780mm) vertical mill build
    By gt40 in forum Vertical Mill, Lathe Project Log
    Last Post: 01-19-2019, 09:26 PM
  2. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  3. New Free CNC Router Plans 12" X 11" x 4", Build for $220 or $105
    By Modular CNC in forum Open Source CNC Machine Designs
    Last Post: 11-25-2013, 12:57 PM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. First build 8020 60"x24"x5" Board Shaper
    By dlyork in forum DIY CNC Router Table Machines
    Last Post: 09-07-2010, 02:32 PM
