586,075 active members*
3,922 visitors online*
Page 5 of 6 3456
Results 81 to 100 of 119
  1. #81
    Oct 2018
    98
    Re: 60" x 40" new build
    Ive decided to fill the void/hollow area in my gantry with epoxy granite. Then i will fill my Ibeam base voids.
    That might dampen some of my harmonics.
    Since none of it will be visible, should i just use sand since i dont care about the finish or looks? I am after rigidity.
  2. #82
    15362
    Quote Originally Posted by Jdubya View Post
    You don't get rigidity by add sand it can dampen some of the harmonics but if you are cutting steel you will need a different spindle to do that successfully
    Mactec54
  3. #83
    Oct 2018
    98
    When i said adding sand, i meant like an 80-90% sand and 20-10% epoxy mix. As in i am not trying to make it look like granite.
    Any spindle recommendations?
  4. #84
    15362
    No spindles that are of the same type you are using are suitable for milling steel, the spindle bearing arrangement that is designed for these high speed spindle is where the problem is, apart from a cartridge type spindle and a independent drive motor I don't think there are any of this type of spindle that is made for low speed use just for steel or any type of metal cutting
    If you take light cuts with what you have and have plenty of time for the job to be done you can use what you have, engraving should not be a problem, it's when using a Endmill it pulls down on the spindle releasing the preload on the bearings once this happens then you have a mess and it does not take much for this to happen
    With the sand mixture unless it can bond to the steel or aluminum it is not going to make it anymore rigid, rigidity starts with the design of the machine adding pieces can help sometimes but it is always best designed for your needs at the start before you build your machine
    Mactec54
  5. #85
    Oct 2018
    98
    Thanks Sir! I have not seen much for low rpm spindles either. I see some interesting 5 bearing power heads with reduction gearing. ( might be interesting) would bumping up to 2.2kv+ 4 bearing with an ER20 collett help?
    I never intended to be cutting steel with this machine but i do have the time and its seemed to work quite well with small bites. Thats really all i need for now as i am just milling holes and slots for now.
    Now that this machine works. I can build the next machine differently.
  6. #86
    15362
    I did find this Spindle which would be a 4 pole, don't know how they have the bearing configuration though and it is a high price
    https://www.aliexpress.com/item/32996693858.html
    Mactec54
  7. #87
    Oct 2018
    98
    Thats got a decent RPM range that i havent seen before, thanks. I will bookmark that for another day...
  8. #88
    Oct 2018
    98
    This spindle unit looks like it could work? . 8k rpms and mentions milling steel.
    I would probably need to switch to the square linear rails instead of my round rails for my z to get any tight tolerances happening.
    Im also thinking about embedding my vise into my frame/base when i do my epoxy fill. Its dovetailed on the bottom side so it would be permanently locked in. It would drop my vice jaws down 2 inches lower. Hmm
  9. #89
    15362
    Yes that is what I was saying when I said having a cartridge type spindle and independent motor, the weight can be a factor that you have to keep in mind with this type of spindle
    Mactec54
  10. #90
    Oct 2018
    98
    I filled my gantry void with epoxy, sand and several sizes of gravel/pebbles. The gantry took less than a cubic foot. My base fame will need about 4 cubic feet.
    I am also replacing my round bar linear rails on my Z axis with 20mm square linear rails. Ive got that about half done now
    Still looking at different spindles for low rpm milling.
  11. #91
    15362
    How did the Gantry work out after filling it
    Mactec54
  12. #92
    Oct 2018
    98
    I am still rebuilding my Z axis rails so I have not cut anything yet, but it sure sounds different when hitting it with a rubber mallet.
  13. #93
    Oct 2018
    98
    I took a chance on that bt30 ebay spindle.
    Looks like it should work fine..
    Attached Thumbnails Attached Thumbnails 20191127_153134.jpg   20191127_161231.jpg
  14. #94
    May 2013
    10
    I'd be interested in purchasing something like this. What do you search for ? who was the seller ?
    Mike
  15. #95
    Oct 2018
    98
    Quote Originally Posted by mjoconr View Post
    Mike
    Search bt30 8000rpm power head spindle and i went with a us seller in cali , yokimm
    Very fast shipping.
  16. #96
    15362
    The only thing I see is the motor to spindle pulley ratio may be a problem having enough torque at lower RPM
    Mactec54
  17. #97
    Oct 2018
    98
    This motors rpm is fixed at 8000rpm, they offer the same one with different gears and belts that is 3000rpms
  18. #98
    Oct 2018
    98
    Closer.
  19. #99
    15362
    If the motor is 3Ph then you could use a VFD Drive and change the speeds if could run at
    Mactec54
  20. #100
    Oct 2018
    98
    Yeah, Unfortunately, its only 110v, single phase with 2 amp draw.
Page 5 of 6 3456
  1. Mark's EPOXY Granite 18"x20"x20" (700mmx780mmx780mm) vertical mill build
    By gt40 in forum Vertical Mill, Lathe Project Log
    Last Post: 01-19-2019, 09:26 PM
  2. How can do ""manual stepper motor sizing for "rack and pinion"calculation""???
    By Medhat93 in forum Mechanical Calculations/Engineering Design
    Last Post: 03-03-2018, 01:50 AM
  3. New Free CNC Router Plans 12" X 11" x 4", Build for $220 or $105
    By Modular CNC in forum Open Source CNC Machine Designs
    Last Post: 11-25-2013, 12:57 PM
  4. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  5. First build 8020 60"x24"x5" Board Shaper
    By dlyork in forum DIY CNC Router Table Machines
    Last Post: 09-07-2010, 02:32 PM
