586,075 active members*
3,841 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Calculating steps per inch - what's wrong with my math??
Results 1 to 6 of 6
    I'm using ClearPath Nema 34 servos with the input resolution set at 6400. They are connected to CNC Router Parts Nema 34 Pro drives at a 3.2:1 ratio.
    My math...
    3.14159 / 3.2 = 0.9817
    6400 / .9817 = 6519.3032 steps per inch.
    But that isn't correct, it's way off.
    Just playing around with numbers in Mach3, it should be closer to 6590.
    What the heck am I doing wrong???
    May 2005
    3920
    I’m on my cell so this might not be wel thought out. In any event the first thing that comes to mind is that that drive is really a gear box and that you are most likely using it in a reduction mode. If that is correct then you need to make 3.2 revolutions of the motor to get one rev off the gear box output shaft. That is 20,480 counts.
    The trouble is this isn’t your counts per inch. To do that you would need to know what the lead of the lead screw is or the ratio to the rack. You don’t have the information needed for a complete answer.
    Quote Originally Posted by bobmagnuson View Post
    My math...
    I really don’t know. At this point we need more information to get anywhere.
    Mar 2008
    1762
    Re: Calculating steps per inch - what's wrong with my math??
    Here's what I get:
    Gary Campbell CNC Technology & Training
    GCnC411 (at) gmail.com www.youtube.com/user/Islaww1/videos
    Its running on a 20 pitch, 20 degree pressure angle rack.
    Not sure what else you'd need.
    - - - Updated - - -
    Quote Originally Posted by islaww View Post
    Here's what I get:
    That's basically what I came up with. But it's not right.
    Jun 2013
    1041
    How are you determining that the steps per you calculated is incorrect?
    Ben
    Sent from my E6810 using Tapatalk
    Jun 2013
    1041
    Oh yeah you all have the same and correct steps per for the counts. The 1 count difference is just a rounding error because you used different methods to get to the same place. Wizard just missed the 1 inch pitch diameter and didn't use that info to divide his answer by 3.14159.
    Ben
  1. Setting up new OMNI 1325 - Need help calculating steps per inch
    By apewrangler in forum Chinese Machines
    Last Post: 03-09-2015, 07:39 PM
  2. Need help! Calculating steps per inch
    By casperround in forum Mechanical Calculations/Engineering Design
    Last Post: 03-22-2013, 08:42 AM
  3. Something HAS to be wrong with my steps per inch....
    By kauaicuda in forum Machines running Mach Software
    Last Post: 09-07-2011, 01:01 AM
  4. Calculating steps per inch!
    By Pplug in forum DIY CNC Router Table Machines
    Last Post: 12-10-2010, 12:03 AM
  5. Steps per inch formula, What I am doing wrong?
    By Noah in forum Gecko Drives
    Last Post: 05-28-2004, 12:56 AM
