586,104 active members*
3,324 visitors online*
    Oct 2018
    Question WIN10 compatible Mach3/4 hardware
    Which (make, type) USB motion card will run MACH3 or MACH4 on a WIN10 laptop?
    Re: WIN10 compatible Mach3/4 hardware
    I would use ethernet rather than USB, as it's much more immune to noise issues than USB controllers.
    There are a ton of controllers that work with Mach3. There are far fewer that work with Mach4.
    While there are some that work with both, most Mach3 controllers don't work with Mach4, and some Mach4 controllers do not work with Mach3.
    Also, keep in mind that there's no guarantee that Mach3 will work with future versions of Windows 10.
    For that reason alone, I'd recommend Mach4 over Mach3.
    For Mach4, look at Vital Systems, ESS, Pokeys, and PMDX.
  1. Best approach to finding compatible hardware
    By grumpygeek in forum LinuxCNC (formerly EMC2)
    Last Post: 01-30-2015, 06:12 AM
  2. New (from the market) Pendant!! Compatible With MACH3?
    By el_tony33 in forum Mach Software (ArtSoft software)
    Last Post: 01-17-2010, 11:48 PM
  3. Mach3 Compatible Axis Warmup Program
    By Phife in forum Mach Software (ArtSoft software)
    Last Post: 01-16-2010, 04:39 AM
  4. Replies: 0
    Last Post: 07-16-2007, 11:44 AM
  5. Mach3/EMC2.0 compatible tool setter required
    By ints99 in forum Calibration / Measurement
    Last Post: 04-08-2007, 07:47 PM
