586,061 active members*
4,673 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Question about CNC tapping
Results 1 to 6 of 6
    Apr 2015
    26
    Although I've been in the business for over 30 years, I've managed to never tap with a CNC mill before. New place I'm working at has a Fadal VMC4020 and I need to be able to do this with it. I don't know if the machine has rigid tapping or not... they've got a floating tap holder, so I figure I'll just pick a low RPM, calculate a feed rate that's just slightly slower than the pitch of the thread, and the floating holder extends just a bit by the time I get through the hole (10-32 through holes in 1/8" aluminum)... Right? Then an M05, followed by an M04, or what?
    Jan 2015
    417
    Re: Question about CNC tapping
    Well easy test go into MDI and type G84.2 enter start , and if the spindle spins 2 or 3 times and then holds it firmly in place ....... you have rigid tapping.
    If the machine is in Format1 the code to do a 10-32 floating tap example
    M6T1 (10-32 FLOATING TAP
    G90G0G17G80
    H1Z.2M7
    G84G99X1.Y1.Z-.75R0+.2F750.Q.0313
    X....Y.....
    X.....Y.....
    G80
    M5M9
    M6T2
    I've tapped thousands of holes on Fadal 3016, 4020 and 6030's. All of ours had rigid tapping option. Even without it you shouldn't need to add extra M05/M04 commands etc. It will still do the same thing with the G84 command minus the precise spindle encoder timing lockup. Basic code as follows should work with a 10-32 tap:
    T3 M06
    G00 G80 G90 S960 M03
    G58 X12. Y-2.
    G43 H03 Z0.5 M08
    G84 G98 Z-0.92 F30. R0.1
    X14. Y-2.719
    X15. Y-4.453 M09
    G00 Z1.
    M01
    I always just add a zero to my thread pitch and program my feed in intervals of 10 IPM. Example 1/2-20 tap runs 400 rpm @ F20 or 600 at F30 etc.
    Jan 2015
    417
    LOL...... this is definitely Halloween because that is a Trick example of a tapping cycle Banjo..... good one
    Thats a snap your tap everytime program...... but that wont happen because the fadal will just give you an error and not run anyways
    Jan 2015
    417
    mwbridgwater you can download all the Fadal manuals here for free here is the part that gives you all the examples of Fixed Cycles https://itscnc.com/images/Sect_4_Fixed_Cycles.pdf
    Apr 2015
    26
    Thanks, rodney!
  1. Question about M29 Rigid Tapping
    By pleasedontcrash in forum G-Code Programing
    Last Post: 06-03-2015, 05:51 PM
  2. Tapping question
    By mike sr1 in forum SprutCAM
    Last Post: 02-08-2013, 04:27 AM
  3. Tapping Question
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 11-10-2012, 07:24 PM
  4. Tapping Question?
    By Phishaholic in forum Tormach Personal CNC Mill
    Last Post: 02-06-2010, 01:13 AM
  5. VF1-4 Tapping Question
    By Greg 24 in forum Haas Mills
    Last Post: 06-20-2007, 04:20 AM
